Snow Leopard on Asus Mobos/Notebooks
Re: Snow Leopard on Asus Mobos/Notebooks
Postby MaLd0n » 21 Aug 2011, 22:28
essential kexts
fakesmc, Batery , audio and PS2
Staff
CPU: i7 5820k
Motherboard: GA X99-UD3P
GPU: GTX 950
Postby t20 » 22 Aug 2011, 23:58
GAAAAA This error is annoying me so much. To get so far only to have an error come up mid-way through installation is really annoying :( Can anyone else help me, I've tried everything and this forum has been the most helpful so far
t20
Postby ctuprde » 23 Aug 2011, 10:45
I installed OSX 10.6.3 to an IDE HDD successfully using Nawcoms Mod CD.
Everything worked fine, until i restarted and plugged in my other SATA drives.
They appear in finder, but when i browse through them the PC locks up and i cant do anything.
I am using the 64bit AppleNForceATA.kext, and everything was working perfectly until i plugged in the SATA drives.
Any ideas?
ctuprde
Postby l0l0 » 24 Aug 2011, 00:16
MaLd0n wrote:essential kexts
Everything works great thanks a lot, the only thing that wont work properly is "sleep" the computer goes on sleep mode when lid is closed or by the power button and it will "return" from sleep after pressing the power button but I get a black screen. Another thing I want to make a donation to you but I noticed that there is a different email cassandro@gmail.com and not the danielmaldonado@gmail.com. Since you are the one doing all the work I wanted to know if you are ok with that. I have no idea how you guys work things out.
l0l0
Postby MaLd0n » 24 Aug 2011, 00:22
donate olarila
the sleep problem ps2 kexts?
Staff
CPU: i7 5820k
GPU: GTX 950
Postby l0l0 » 24 Aug 2011, 03:07
donate olarila
MaLd0n wrote:Image
DONE!!! ;)
No MaLd0n removing the PS2 kext didn't fix the problem. In Lion if I put the computer to sleep it wont wake and have to force it to shut down using the power button and when I turn it back on it will reset the computer's bios. "weird" Because in my Snow leopard partition I have to force the computer to shut down using the power button too but when I turn it back on what I get is the computer returning from sleep.
l0l0
Postby MaLd0n » 24 Aug 2011, 04:07
l0l0 wrote:No MaLd0n removing the PS2 kext didn't fix the problem. In Lion if I put the computer to sleep it wont wake and have to force it to shut down using the power button and when I turn it back on it will reset the computer's bios. "weird" Because in my Snow leopard partition I have to force the computer to shut down using the power button too but when I turn it back on what I get is the computer returning from sleep.
Code: Select all
sudo perl -pi -e 's|\x8b\x45\xc8\x39\x45\xcc\x74\x0b|\x8b\x45\xc8\x39\x45\xcc\xeb\x0b|; s|\x8b\x45\xb4\x39\x45\xb8\x74\x08|\x8b\x45\xb4\x39\x45\xb8\xeb\x08|' /System/Library/Extensions/AppleRTC.kext/Contents/MacOS/AppleRTC
Code: Select all
fix cmos reset after sleep
back up AppleRTC
Staff
CPU: i7 5820k
GPU: GTX 950
Postby l0l0 » 24 Aug 2011, 04:25
MaLd0n wrote:
Code: Select all
Code: Select all
back up AppleRTC
That fixed the Bios reset issue in Lion thanks, any more ideas about video not returning from sleep (laptop screen or the external monitor)
l0l0
Postby MaLd0n » 24 Aug 2011, 04:29
l0l0 wrote:
MaLd0n wrote:
Code: Select all
Code: Select all
back up AppleRTC
I have no idea :shock:
Staff
CPU: i7 5820k
GPU: GTX 950
Postby l0l0 » 24 Aug 2011, 04:42
MaLd0n wrote:
l0l0 wrote:
MaLd0n wrote:
Code: Select all
Code: Select all
back up AppleRTC
Thanks anyway. I guess I have to be committed to have a Laptop without sleep. (It's just going to be a tired laptop) :)
Once more thanks!
l0l0
PreviousNext
Return to Guides and tutorials
