Mojave / Catalina on Mobos Series 100/200/300 with OpenCore 0.5.3
Post by MaLd0n » 27 Oct 2019, 14:15
acdindia, extract new send_me
Added in 4 minutes 3 seconds:
mgw_smy,
SysAdminPgh
CPU: Intel i7-7770
Motherboard: z270
GPU: RX580
Post by SysAdminPgh » 27 Oct 2019, 15:01
Hi... Thanks for the help but still won't work with the RX580. I did notice that in Graphics Injector it lists the video card as a RX480 rather than a RX580. Should I give up on this card and return it? Never had issues before like this. Nothing changes but the video card. I've taken another Send Me and a screen shot in case they might help. Again thanks!
Post by MaLd0n » 27 Oct 2019, 15:04
SysAdminPgh, use weg kext and disable intelhdgraphics in bios/uefi, u need configure this IGPU
acdindia
Post by acdindia » 27 Oct 2019, 15:22
27 Oct 2019, 14:19
mgw_smy, DSDT.aml.zip
Ok. Here is the file.
Send me Adityas-MacBook-Pro.zip
Please note that I've extracted this from a system booted using your provided DSDT.
If you require, I'll try booting without DSDT and extract again.
Thanking you!
Post by MaLd0n » 27 Oct 2019, 15:29
acdindia,
UR TRACKPAD IS JUST A KEXT, I THINK UR DEVICE IS NOT I2C
acdindia
Post by acdindia » 27 Oct 2019, 15:37
27 Oct 2019, 15:29
acdindia, DSDT.aml.zip
Thank you!
I'll give it a try. Maybe I'll have to hunt for other kexts.
Will report back with results.
Thanks again MaLd0n! :crazy:
Added in 21 minutes 42 seconds:
MaLd0n, Sorry but it didn’t work. :help
If I boot with my charger plugged in, it’ll keep showing me “Plugged in” even if I unplug it and if I boot unplugged, it’ll keep showing me “On battery” even if I plug it.
Bluetooth hardware not found.
Camera, not found.
Trackpad, same. Can’t even click and drag. Even the trackpad buttons are non-functional. :hammer
:help Please help.
Post by MaLd0n » 27 Oct 2019, 22:32
acdindia, u need solve usb
use battery plugin from virtual smc project
MorenoAv
CPU: i5 9600K
Motherboard: GA Z390 - I Aorus Pro Wifi
GPU: Intel UHD 630
Post by MorenoAv » 27 Oct 2019, 23:32
Hi good night to all,
MaLd0n, i booted with your EFI, but my sound is gone could you help me with that?
mgw_smy
CPU: i5-8400
Motherboard: z370-a
GPU: rx570
Post by mgw_smy » 28 Oct 2019, 10:01
27 Oct 2019, 14:19
Thank you!
Post by MaLd0n » 28 Oct 2019, 12:43
MorenoAv, full dump
--Run_Me
MorenoAv
CPU: i5 9600K
GPU: Intel UHD 630
Post by MorenoAv » 28 Oct 2019, 23:08
Hi MaLd0n,
Here it is this time I think is the right one...
Thanks in Advance
Post by MaLd0n » 28 Oct 2019, 23:44
MorenoAv,
Arquivo Comprimido.zip
SysAdminPgh
CPU: Intel i7-7770
Motherboard: z270
GPU: RX580
Post by SysAdminPgh » 29 Oct 2019, 20:41
MaLdOn I added WEG. Not sure why I removed it. I only have two graphic choices in this BIOS. Initiate Graphic Adapter which I set to PEG and IGD Multi-Monitor which I set to Disabled. No IntelGraphics even in OC section. Can you point me in the right direction on how to configure the iGPU? I thought this video card was good to go without having to do anything. Does it matter that it is a XFX card?
Thanks!
Post by MaLd0n » 29 Oct 2019, 21:48
SysAdminPgh, Asus mobo is Multi Monitor option
anibalin
Post by anibalin » 29 Oct 2019, 23:14
Hi MAldon!
Wondering Im not getting any list on PCI as you do?
Post by MaLd0n » 30 Oct 2019, 00:35
anibalin, hey
is a full dsdt patch, cosmetics. essentials, removed unused devices, etc ;)
SysAdminPgh
CPU: Intel i7-7770
Motherboard: z270
GPU: RX580
Post by SysAdminPgh » 30 Oct 2019, 02:07
MaLdOn - Did your suggestions and I end up with the following....
AMF: No Slide Values are usable! Falling back to 0 with 0x0D68A000 bytes!
Error Allocating 0x11BD6 pages at 0x00000000046C8000 alloc type 2
Couldn't allocate runtime area
Boot failed: Will sleep for 10 seconds before exiting
Never exits.
Any other suggestions before this card goes into the Mon river?
Thanks!
Post by MaLd0n » 30 Oct 2019, 02:10
SysAdminPgh, u have my full dsdt patch?
SysAdminPgh
CPU: Intel i7-7770
Motherboard: z270
GPU: RX580
Post by SysAdminPgh » 30 Oct 2019, 03:04
It's in the ACPI/patched folder. When I downloaded the Read me file it was with the 1050 Ti video card installed. I get no where with the RX580. Does that matter? Want to see my EFI?
acdindia
Post by acdindia » 30 Oct 2019, 04:24
27 Oct 2019, 22:32
Hey MaLd0N! :superman
Finally, I was able to solve my USB issues by using USBInjectAll.kext and a custom SSDT to disable any unused ports.
This brought my Bluetooth, camera and don't know how Trackpad in action!
But, sadly, battery seems to be an issue. :/
I'm using battery kext from the VirtualSMC project.
Anything else that I must try? :help
Also, the battery seems to drain really fast, I mean, really really fast..! :hammer
NVIDIA is disabled in DSDT as I can't see it in my system preferences. What might be an issue ?
How may I say if my Hacky is tuned and needs no more work ?
Apologies for too many questions!
Thank you for all your help! :frantics
