Ad blocker detected: Our website is made possible by displaying online advertisements to our visitors. Please consider supporting us by disabling your ad blocker on our website.
-->Donations via PayPal [External Link Removed for Guests]
- Site Admin
- CPU: i9-9900K
- Motherboard: GA Z390 M GAMING
- GPU: RX 590 8 GB
Post
by MaLd0n » 16 Jun 2019, 14:47
Problems with Paypal? Check Here [Local Link Removed for Guests]
Useful Links [Local Link Removed for Guests]
Olarila Hackintosh Builds [Local Link Removed for Guests]
Donated? Send me one Private Message
- Site Admin
- CPU: i9-9900K
- GPU: RX 590 8 GB
Post
by MaLd0n » 17 Jun 2019, 18:36
new beta
- Site Admin
- CPU: i9-9900K
- GPU: RX 590 8 GB
Post
by MaLd0n » 18 Jun 2019, 00:07
shira
- CPU: core i5 900k
- Motherboard: asus
- GPU: amd
Post
by shira » 19 Jun 2019, 13:31
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]16 Jun 2019, 14:47
-FIX ERRORS AND WARNINGS
-FIX ACPI ERRORS
-REMOVE UNUSED
-HIGH PRECISION EVENT TIMER
-SATA SERIE 11 ID
-DMAC
-REMOVE LINES, PROBLEMATIC and UNUSED
-FIX K.P in REBOOT
-NVRAM / REAL TIME CLOCK
-SLPB
-DARWIN / WINDOWS 2015
-XHCI
-PLUGIN TYPE
-HDAS to HDEF
-HDEF
-REAL TIME CLOCK
-ARTC
-IPIC
-TIMR
-SBUS
-MIKEY
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-UAR1
-LAN
-FWHD
-USBX
-PMCR
-PPMC
-XSPI
-GMM
-IMEI
-EC
-PNLF
-ARPT
-GFX0
-NVME
-DTGP
-ACQUIRE MUT0 0XFFFF
-OPERATION REGION GPIO
-MUTEX MUT0 0x00
-EXTERNAL REFERENCES
-UNKNOWNOBJ
-HDMI / HDAU
-FULL RENAMED DEVICES
shira
- Site Admin
- CPU: i9-9900K
- GPU: RX 590 8 GB
Post
by MaLd0n » 19 Jun 2019, 22:02
shira,
zee.malik2008
- CPU: Dell Latitude E6420
- Motherboard: Intel
- GPU: Intel HD 3000
Post
by zee.malik2008 » 22 Jun 2019, 06:32
Sierra Installtion error during installtion i have just download , make bootable usb with balenaEtcher and try to install.
zee.malik2008
gnodhn
- CPU: i7 7700hq
- Motherboard: msi gp72m 7rex
- GPU: 1050ti
Post
by gnodhn » 22 Jun 2019, 09:25
Im gonna build one using your mother board (giga z390m).
Please share your z370m patched dsdt and tell me which bios version you are using @Maldon
gnodhn
- Site Admin
- CPU: i9-9900K
- GPU: RX 590 8 GB
Post
by MaLd0n » 22 Jun 2019, 10:10
gnodhn, f6, folder in first post
pcit
- CPU: Skylake
- Motherboard: Dell
- GPU: HD520
Post
by pcit » 23 Jun 2019, 03:45
Hi everyone , can i have the patched dsdt for 100 series , i cant find any dsdts in clover efi as it is shown in this post , Thank you
pcit
- Site Admin
- CPU: i9-9900K
- GPU: RX 590 8 GB
Post
by MaLd0n » 23 Jun 2019, 03:51
pcit, u need post ur files
--Run_Me
madlotus
- CPU: Intel Core i7-2600K
- Motherboard: ASUS P8H67-M EVO
- GPU: Zotac GeForce GTX 1060 AMP!
Post
by madlotus » 23 Jun 2019, 18:39
thanks bro i'm going to try to install with success the last catalina beta 2
madlotus
pcit
- CPU: Skylake
- Motherboard: Dell
- GPU: HD520
Post
by pcit » 24 Jun 2019, 00:38
thank you MaLd0n , i have it fully working , i added the properties , used the same patches on the efi in this post , installer working well , system is stable , i need to update to the new oc releases to keep my system updated with the new oc releases , i will adding try certain lines and will see if it all works , thank you
pcit
- Site Admin
- CPU: i9-9900K
- GPU: RX 590 8 GB
Post
by MaLd0n » 24 Jun 2019, 00:46
just enjoy
KnightRiderX420
- CPU: 13 6100 8gb ddr4
- Motherboard: asrock pro4 h270m
- GPU: red devil rx 580 8gb
Post
by KnightRiderX420 » 24 Jun 2019, 06:02
I have a random but relevant question. I have a a7000 nighthawk usb dual channel usb wifi adapter that was fully compatable with high sierra and all b4 it but when i install this beta, it says tray utility isn't compatable so i cannot connect. is there any other tray app i can use that will work? in linux the rtl8814AU driver install works to unlock and recognize the device so both bands work. I am at a loss as i have no pan cables in the room and the drivers for mocks on the site are till the same... any ideas. thanks
KnightRiderX420
- Site Admin
- CPU: i9-9900K
- GPU: RX 590 8 GB
Post
by MaLd0n » 24 Jun 2019, 14:17
KnightRiderX420, u can check here
GabrielIg
- CPU: HP 15-bs212
- Motherboard: Intel Core i7 7000u
- GPU: Intel HD 620
Post
by GabrielIg » 27 Jun 2019, 11:49
Hi. I'm new here. I installed MacOs Catalina Beta public. I'm having problems with No TouchID.Ketx (-nobiobeta). It does not work well at all. Where can you get the new kexts already updated, for Catalina ?.
Thanks.
GabrielIg
- Site Admin
- CPU: i9-9900K
- GPU: RX 590 8 GB
Post
by MaLd0n » 27 Jun 2019, 12:04
GabrielIg, [External Link Removed for Guests]
GabrielIg
- CPU: HP 15-bs212
- GPU: Intel HD 620
Post
by GabrielIg » 27 Jun 2019, 12:45
GabrielIg
neknofelom
- CPU: i5-8400
- Motherboard: ASRock b360m Pro4
- GPU: Intel UHD 630 / GTX 1080ti
Post
by neknofelom » 27 Jun 2019, 20:03
I have a ASRock b360m pro4 motherboard with intel i5-8400 and currently running intel uhd 630 gpu. I have a deactivated gtx 1080ti which I only use for gaming in windows 10 (dual boot). Currently successfully running Mojave 10.14.6 but can't get Catalina to work, I get this kernel boot error everytime. I use -lilubetaall and have latest lilu.kext and whatevergreen.kext as well as latest clover. Anyone?
neknofelom
- Site Admin
- CPU: i9-9900K
- GPU: RX 590 8 GB
Post
by MaLd0n » 27 Jun 2019, 21:44
neknofelom, use iMac18,1 smbios and create one patch with hackintool
