OS X 10.8 Mountain Lion bootable USB
Cassio
Re: OS X 10.8 Mountain Lion bootable USB
Post by Cassio » 30 Jul 2012, 15:43
raxittt wrote:still waiting for root devices...
what should i need to do..?
Try this (debug=8 ahcidisk=1 to boot, then patch kext with script)
raxittt
Post by raxittt » 30 Jul 2012, 18:19
Cassio wrote: Try this (debug=8 ahcidisk=1 to boot, then patch kext with script)
sorry but would you please tell me how to patch kext. i have never done this before. :oops:
i've searched also a lot for this but i can't get through it..
devilindisguise
Post by devilindisguise » 31 Jul 2012, 01:31
When installing kexts using the Kext Wizard, where should you install them to? The extra folder or System/Library/Extentions ?
Whats the difference between the two?
Is there anything else you need to do after clicking on install? just reboot?
Cassio
Post by Cassio » 31 Jul 2012, 01:46
raxittt wrote: sorry but would you please tell me how to patch kext. i have never done this before. :oops:
If you can get in the system with the boot flags, just double click the patcher script, it will ask your admin password.
devilindisguise wrote:When installing kexts using the Kext Wizard, where should you install them to? The extra folder or System/Library/Extentions ?
Always /S/L/E, kexts in /E/E won't be loaded if you use kernelcache (which is recommended) and kexts with dependencies won't work from Extra.
devilindisguise
Post by devilindisguise » 31 Jul 2012, 01:48
Do i need to repair permissions, rebuild cache after installing the kexts?
Cassio
Post by Cassio » 31 Jul 2012, 01:50
I guess the app does that automatically, but if you feel it doesn't, click those options, it won't hurt.
devilindisguise
Post by devilindisguise » 31 Jul 2012, 02:32
For some reason now, the kext wizard is not able to find the target drives. it cant find the mac drive nor the usb drive to install the kexts to.
The first time i loaded it up it was able to detect the mac and the usb drive. but now it cant.
im also not able to see the mac drive in Finder. I can see all my other drives and the usb drive there.
any ideas?
Cassio
Post by Cassio » 31 Jul 2012, 02:50
Try installing it via terminal
There are other tools like Kext Wizard (Kext Utility, for example).
About Finder, it's normal. Go to computer (menu Go in Finder) and drag the HD to sidebar.
tunjevinac
Post by tunjevinac » 31 Jul 2012, 10:41
can i use this version of Mountain Lion on AMD cpu (AMD Athlon II X3 445, 3,1GHz)?
i tried, and after first menu, where you can choose from whitch partition or device you wish to boot, after i choose OS X 10.8, my pc starts to load something and then just reset...
is there any solution?
thank you!
Cassio
Post by Cassio » 31 Jul 2012, 12:52
No, it's only for Intel.
nikss5000
Post by nikss5000 » 31 Jul 2012, 13:40
You need at least one free partition, use Disk Utility (in the Utilities menu) to erase it as Mac Os Extended (Journaled).
If you want to install Chameleon (the boot loader) in this partition and you use MBR (not GUID, like if you already have Windows in the HD), it must be a primary (not extended/logical) partition.
Hey i am new too all these hackintosh stuff... Its a pretty nice guide and as simple as it can be ... but i am having a little problem with my HDD .. as i have three drives connected i can install a complete version on 1 drive or any other partition ... but the problem i m having is .. i cant see any hd or partition in the OSX DISK Utility Menu ... Can anyone pls help ?
Motherboard - Asus P8B WS - Processor - Intel I7 2600K @ 3.40 ghz - RAM - 8 GB Corsair Memory - HARD DISK - 3 Sata's
Cassio
Post by Cassio » 31 Jul 2012, 13:54
Go into BIOS setup and configure SATA as AHCI.
Peterag
Post by Peterag » 31 Jul 2012, 19:53
internal HDD is not listed for installation. I can see only the USB Drives. Storage in the BIOS is setup only in AHCI mode. I am using a dell Inspiron 1525 machine. Please help.
Cassio
Post by Cassio » 31 Jul 2012, 20:24
Not listed as install target, or not listed in disk utility? You need to format the partition first.
amadoro
Post by amadoro » 01 Aug 2012, 04:06
@ Cassio,
I manage to install and follow the guide..thank you.
i'm trying to boot with my hd and it showed this pic,please see photo.
thanks
Specs:
Gigabyte Z77X-D3H
Ivy-Bridge i5=3450
8gig DDR3 1600
Cassio
Post by Cassio » 01 Aug 2012, 04:42
disk1s1 is the OS X partition? If it's not, it may be a video issue [Local Link Removed for Guests]
clintoy
Post by clintoy » 01 Aug 2012, 07:44
hi, i was able to install mountain lion but i cant seem to install any other app. it keeps asking for the admin login and the account created at initial startup is only a standard account. i need help getting the admin access. thank you. :D
danmar
Post by danmar » 01 Aug 2012, 11:25
Hello, I have the following computer:
ASUS P8H67-M LE(B3), H67, Socket 1155, DDR3, mATX
Intel Core i3-2120, 3.30ГГц, 3МБ, LGA1155, BOX
DDR3, 8ГБ (2x4ГБ), PC3-10600, 1333
Unfortunately, I run in to a similar problem every time I try to boot:
using 64-bit bootcache playlist
BootCacheControl: Unable to open /var/db/BootCache.playlist: 2 No such file or directory
USBF: 8.721 AppleUSBEHCI[0xffffff801177b000]::Found  transaction which hasn't moved in 5 seconds on bus 0x1d, timing out! (Addr: 7, EP: 0)
ACPI_SMC_PlatformPlugin::start - waitForService(resourceMatching(AppleIntelCPUPowerManagement) timed out
I haven't tried deleting any kex's yet. Which ones should I try?
danmar
Post by danmar » 01 Aug 2012, 11:43
If you just type this without the -x or -f it works.
So that's just:
GraphicsEnabler=No
My problem i solved.
ozmikeli
Post by ozmikeli » 01 Aug 2012, 13:42
Hey guys
i'm looking in dual boot win 7 and osx mt on my acer aspire v3-571g. what are the step i have to go through? i'm downloading "OS X 10.8 Mountain Lion bootable USB for Intel PCs" at the moment and have split my hdd into 2 partitions.
cheers
