olarila.com
Mac OS X x86 - Hackintosh
It is currently 20 May 2013, 05:27
Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
Author Message
PostPosted: 23 Oct 2011, 15:28
Noob
I've also applied the patch you gave me but the kext isn't loaded. Any ideeas??? Thank you!
Top
 Profile
PostPosted: 23 Oct 2011, 16:31
iGenius
No idea. Maybe the kext just doesn't work.
_________________
Top
 Profile
PostPosted: 23 Oct 2011, 20:17
Noob
Thank you for your help and for your time.
Top
 Profile
PostPosted: 02 Nov 2011, 13:20
GeekInTraining
hello oldnapalm,
i'm having problem with DSDTEditor. I have sony vaio vpceb36fg laptop & i'm trying to install snow leopard 10.6.3 Retail DVD on it but i'm getting errors. I tried with iboot,iboot legacy, Empire_EFI, LegacyEmpire_EFI, Darwin Boot tools, & at last not least chameleon manually on the disk.
I Tried it with my internal dvd rom AD-7700h & now my DVD writer is not working & now i restore the dvd's iso( made earliar )on a pendrive with my vmware8 machine &still i got errors.Then i read abt DSDT & I came here to this form via tonymacosx86.com .
I got a working DSDT of vpceb34en from http://www.osx86.net. it nearly match my system spec like cpu ,chipset, dvd,gpu ati, and screen 15.5 but i have a full HD Display, & ram,hdd & gpu are different.I tried with it but no luck.
Now i found a patch of vpcea16fg.i didn't find find patch for my bios DSDT which i exracted with DSDT editor. so the spec of the vpcea16fg are closely matches to my system even os except the cpu i have i& the display. i tried this patch on my DSDT & go to the installation process still there was no luck. then i tried this vpcea16fg patch to the working DSDT of vpceb34en & still no luck with this time also.
I tried the two editors DSDTSE & the DSDTeditior & patch the DSDT.dsl i'm getting error like "error object not found " with no name of the error. i'm attaching the extraced with all the dwnd files plz help......
the errors im getting with the DSDT are:-
ATI VGA Controller [1002:68c1] : : PCI Root(0*0)/Pci(0*1,0*0)/Pci(0*0,0*0)
old Pci Command - 7
boot display -0
dumpingPci config space. 256 bytes
wrong BIOS signature : 0000
not going to use bios image file
found bios image
adding binimage to card 68c1 from legacy space with size ee00
Lan controller [11ab:4381] : : PciRoot(0*0)/Pci(0*1C,0*2)/Pci(0*0,0*0)
setting up lan keys
loaded HFS+ file :[Extra/smbios.Plist] 468bytes from 4253970.
Patche DMI Table.
Loaded HFS+ : [Extra/DSDT.aml] 43071 bytes from 4253790.
Patched ACPI Version 2DSDT
Starting Darwin iso.
all that..
& with iBOOT legacy the errors are:-
Using PciRoot-UID Value : 0
frame buffer @0*e0000000 MMIO @0*f0020000 I/O port @0*0000D000 ROM Addr @0*f000000
Ati card Posted,reading VBIOS from legacy space
memmory allocation error ! Addr=0*deadbeef, size=0*0, file=ati.c, Line=739
This is a non recoverable error ! System Halted ! ! !
that'all
One Thing My bios is aptio setup utility 1.28.1119 copyright AMERICAN MEGATRENDS Inc.
i can access only my date , time, virtualization ,c3/c6, security & boot devices from my bios. I read abt that this bios is efi enabled then why can't i boot direct from the dvd or usb disk. i have spalshtop browser in my laptop which starts without os start or preboot without os. Is there any supervisor mode in the bios which stops me to access.How can i access full functions of this BIOS??
MY Hardware specs are:
Product : sony vaio vpceb36fg
Bios : sony bios ( aptio setup utility 1.28.1119 copyright AMERICAN MEGATRENDS Inc.)
cpu : intel core i3-370M processor 2.40 GHz
chipst : HM55
Ram : 4 GB DDR3
GPU : 1 GB DDR3 ATI Radeon HD 5650
DVD : sony optiarc ad-7700h
HDD : 500 GB Toshiba MK5065GSX
Display : Full HD (1920*1080)
wireless : Atheros AR9285 Wireless Network Adapter
lan : Marvell Yukon 88E8059 PCI-E Gigabit Ethernet Controller
sound : ATI HDMI Audio & Realtek High Definition Audio
i' m attching the files with system information via cpu-z
Thank's in advance.
_________________
sony vaio vpceb36fg |sony bios ( aptio setup utility 1.28.1119 AMI)
intel core i3-370M processor 2.40 GHz | HM55 | 4 GB DDR3 | GPU : 1 GB DDR3 ATI Radeon HD 5650 M
sony optiarc ad-7700h | 500 GB Toshiba MK5065GSX |FullHD : 1920*1080|
Top
 Profile
PostPosted: 02 Nov 2011, 15:46
iGenius
A patched DSDT won't help you to install Mac OS, you must be able to install using original DSDT from BIOS. With the system running you can patch DSDT to fix possible problems.
Should be fixed by the "fix errors" button in the compile window. All these errors are caused by 2 syntax errors.
_________________
Top
 Profile
PostPosted: 02 Nov 2011, 19:20
GeekInTraining
Thank You Casio for a speedy reply,
As I mentioned i'm not able to fix the DSDT errors in windows. they aren't fixed by the DSDTSE methods. i applied the "Notebook Core i Nehalem" patches & i compiled it then i got 178 errors, before applying patches i got 166 errors. i 'm not able to fix the DSDT. Now what should i do find a way ...
Thank you.
_________________
Top
 Profile
PostPosted: 02 Nov 2011, 19:40
iGenius
Just comment this (add // before each line)
Code:
//                If (LNotEqual (TBAB, Zero))
PARSEOP_IF can't be directly inside a device, just inside a method (syntax error, unexpected PARSEOP_IF).
Click on the syntax errors in the compile window to find it, there are 2 instances.
The Mac version auto fixes it, I just tried, should work in Windows too.
There's one error left, easy fix (Length = Maximum - Minimum + 1)
Code:
DWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, Cacheable, ReadWrite,
0x00000000, // Granularity
0x00000000, // Range Minimum
0xFEAFFFFF, // Range Maximum
0x00000000, // Translation Offset
0xFEB00000, // Length
,, , AddressRangeMemory, TypeStatic)
_________________
Top
 Profile
PostPosted: 02 Nov 2011, 20:15
GeekInTraining
Thank you casio,
first one i understand, & it completely worked in windows. but what abt the second one , what should i have to do with it , should i copy this code where the error is occured or what?? and what abt the warning??.
the _T_0 ,_T_1...... warnings are solved with replace _T_0 to T_0 , _T_1 to T1.....
& any other patches should i use to patch the DSDT..like power button , lid , wirless, EHCI , RTC & all...
i'm attaching system info of hardware which is compatible for OS X. what patches should i use??
Thank you.
_________________
Top
 Profile
PostPosted: 02 Nov 2011, 20:39
GeekInTraining
rajverma2255 wrote:
Thank you casio,
Thank you.
ok now i under stand what to do , i've done this & still there is no joy, i' m getting that same error i mentioned with dsdt ....
what to do...
_________________
Top
 Profile
PostPosted: 02 Nov 2011, 20:46
iGenius
You mean the error in boot, or error in compilation?
Read my first reply
_________________
Top
 Profile
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
Search for:
Jump to:
