olarila.com
Mac OS X x86 - Hackintosh
It is currently 24 May 2013, 14:50
Post new topic Reply to topic  [ 147 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 15  Next
Author Message
 Post subject: Re: Patches
PostPosted: 15 Sep 2011, 16:32
Noob
Cassio wrote:
I believe the patch in first post is the same, no improvements, so you just need to enable generate P and C states and remove the kexts.
You can use this to configure Chameleon
http://www.insanelymac.com/forum/index. ... pic=257464
Thanks! Will it work with Chimera bootloader?
Top
 Profile
PostPosted: 15 Sep 2011, 16:58
iGenius
I never tested, but I think it should work.
_________________
Top
 Profile
PostPosted: 15 Sep 2011, 17:16
Noob
One last question: are you 100% sure, that removing "NullCPUPowerManagement.kext" won't crash my system?
Top
 Profile
PostPosted: 15 Sep 2011, 17:18
iGenius
No, if you don't have the LPC and HPET patches in DSDT and don't enable generate states in Chameleon it will probably crash.
Have a working boot CD just in case.
_________________
Top
 Profile
PostPosted: 15 Sep 2011, 17:21
Noob
Thank you very much! :D
Top
 Profile
PostPosted: 18 Sep 2011, 19:21
Noob
Cassio wrote:
What problem did you have? Give more details.
I've upgraded to SL lion still have problems of instability, while working ognitanto panics and goes into panic at startup.
I would like to do a clean install of LION DSDT but I would have at least that's fine delivery with a certainty.
thanks for your answer
Top
 Profile
PostPosted: 19 Sep 2011, 16:57
iGenius
The patch GA EP31-DS3L is available in first post, apply it using DSDT Editor.
_________________
Top
 Profile
PostPosted: 19 Sep 2011, 17:42
Noob
"GA-EP31 DS3L" and "GA P31DS3L" are not two different plates?
at least seeing the Gygabite look different.
Top
 Profile
PostPosted: 19 Sep 2011, 17:54
iGenius
They are almost identical, I think the same patch will work.
Quote:
North Bridge: Chipset Intel® P31 Express
South Bridge: Intel® ICH7
_________________
Top
 Profile
PostPosted: 13 Oct 2011, 07:16
Noob
Hi guys,
I have a Asus G53SX Notebook and I couldnt find a DSDT patcher for it. It's really similar to the one here called G53SW except it has a geforce gtx 560m 2gb instead of 460m... would it work for me? Could I change that info there? Or should I request a new DSDT?
Thanks!!!
Top
 Profile
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
