olarila.com
Mac OS X x86 - Hackintosh
It is currently 19 Jun 2013, 07:35
Post new topic Reply to topic  [ 398 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 40  Next
Author Message
 Post subject: Re: DSDT Auto-Patcher
PostPosted: 21 Jul 2011, 18:42
Noob
Hi Mald0n,
can you please make a DSDT for my mobo?
this is my configuration:
-MB: intel dx58so2
-CPU: i7-960
-GC: GTX560
thank you in advance!
Top
 Profile
PostPosted: 21 Jul 2011, 19:03
Staff
leandrouzzou wrote:
Hi Mald0n,
-MB: intel dx58so2
-CPU: i7-960
-GC: GTX560
send me files
see the first post
_________________
Top
 Profile
PostPosted: 21 Jul 2011, 23:05
Noob
MaLd0n wrote:
leandrouzzou wrote:
Hi Mald0n,
-MB: intel dx58so2
-CPU: i7-960
-GC: GTX560
send me files
see the first post
what files?
Top
 Profile
PostPosted: 22 Jul 2011, 00:02
Staff
leandrouzzou wrote:
what files?
run on terminal
Code:
perl -e 'open(CMD, "ioreg -lw0 \| grep DSDT|") or die; while(<CMD>) { chomp; if($_ =~ /\"DSDT\.?\d?\"=<([^>]*)>/) { $buff = $1; open(PIP, "|xxd -r -p > ~/Desktop/dsdt.aml") or die; print PIP "$1"; } }'
DSDT generate in desktop
_________________
Top
 Profile
PostPosted: 22 Jul 2011, 08:25
Noob
MaLd0n wrote:
diman1 wrote:
This is unresolved problem??? And this is the problem with Ethernet kext???
I dont know, i just ask you.
Yes
look at the photo --> "Kernel Extensions in Backtrace"
MaLD0n
Can you edit my DSDT(audio section), so as not use VoodooHDA(use native AppleHDA). My laptop have HDMI 5650m and internal speaker???
Everest say:
PCI / PnP Audio
Device Description Type
Conexant Cx20585 @ Intel Ibex Peak PCH - High Definition Audio Controller [B-2] PCI
High Definition Audio Controller [1002-AA60] [NoDB] PCI
HD Audio
[ High Definition Audio Controller [1002-AA60] [NoDB] ]
Device Properties:
Device Description High Definition Audio Controller [1002-AA60] [NoDB]
Device Description (Windows) High Definition Audio Controller
Bus Type PCI
Device ID 1002-AA60
Subsystem ID 1179-FD12
Revision 00
Hardware ID PCI\VEN_1002&DEV_AA60&SUBSYS_FD121179&REV_00
[ ATI Radeon HDMI ]
Device Properties:
Device Description ATI Radeon HDMI
Device Description (Windows) Conexant Audio Driver For AMD HDMI Codec
Device Type Audio
Bus Type HDAUDIO
Device ID 1002-AA01
Subsystem ID 00AA-0100
Revision 1002
Hardware ID HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1002
[ Intel Ibex Peak PCH - High Definition Audio Controller [B-2] ]
Device Properties:
Device Description Intel Ibex Peak PCH - High Definition Audio Controller [B-2]
Bus Type PCI
Device ID 8086-3B56
Subsystem ID 1179-FF1E
Revision 05
Hardware ID PCI\VEN_8086&DEV_3B56&SUBSYS_FF1E1179&REV_05
[ Conexant Cx20585 ]
Device Properties:
Device Description Conexant Cx20585
Device Description (Windows) Conexant CX20671 SmartAudio HD
Device Type Audio
Bus Type HDAUDIO
Device ID 14F1-5069
Revision 1003
Hardware ID HDAUDIO\FUNC_01&VEN_14F1&DEV_5069&SUBSYS_1179FD12&REV_1003
Second question:
What you recomends to use Hyper Threath and Hyper Boosts of i5???
Top
 Profile
PostPosted: 22 Jul 2011, 08:49
Noob
this is what did you ask me. ;)
Top
 Profile
PostPosted: 22 Jul 2011, 19:27
Noob
MaLd0n wrote:
driftkingn20 wrote:
Help me Please In page9
8-)
send me your DSDT
Top
 Profile
PostPosted: 22 Jul 2011, 22:02
Staff
driftkingn20 wrote:
MaLd0n wrote:
8-)
send me your DSDT
run on terminal
Code:
send me DSDT generate in DESKTOP
_________________
Top
 Profile
PostPosted: 22 Jul 2011, 22:05
Staff
Use NativePM + LPC + HPET fix(if you need) + correcty MacModel
_________________
Top
 Profile
PostPosted: 26 Jul 2011, 01:43
GeekInTraining
Hi.
Can you make a DSDT for me? Here's my spec:
Mobo : ASUS Maximus IV Extreme
Ram : 8 gb DDR3 (4g+2g+1g+1g) running at 1033 (Yes I know it's slow as hell, I WILL upgrade :D )
Gfx : Gigabyte Nvidia GTX 460 1g
Thanks!
Top
 Profile
Search for:
Jump to:
