olarila.com
Mac OS X x86 - Hackintosh
It is currently 19 Jun 2013, 21:56
Post new topic Reply to topic  [ 398 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 40  Next
Author Message
 Post subject: Re: DSDT Auto-Patcher
PostPosted: 17 Jun 2011, 18:31
Noob
MaLd0n wrote:
pawo99 wrote:
the problem is CST
add in boot.plist
Code:
<key>GeneratePStates</key>
<string>Yes</string>
<key>GenerateCStates</key>
send me kextstat
run on terminal
I tried this but Lion stops booting with this kernel.log in attachment.
Top
 Profile
PostPosted: 17 Jun 2011, 18:57
Staff
only
Code:
try it
fakesmc not loaded
_________________
Top
 Profile
PostPosted: 17 Jun 2011, 19:22
Noob
MaLd0n wrote:
only
Code:
try it
fakesmc not loaded
Tried, Lion boots but when I put it into sleep, only monitor is in sleep mode, but fans are still on and leds on keyboard has lights on.
I have no idea what now :(
Top
 Profile
PostPosted: 23 Jun 2011, 19:46
Noob
Hey man, it was suggested I ask you to make a DSDT for me instead of trying to make my own. So, I thought I would.
Can you make me a DSDT for the GA-890FXA-UD5 motherboard? I would really really appreciate it.
Here is the send_me.zip file: http://dl.dropbox.com/u/20073702/send_me.zip
Top
 Profile
PostPosted: 23 Jun 2011, 22:58
Staff
dsdt.killer1390 .zip
AMD - No nativePM etc
_________________
Top
 Profile
PostPosted: 23 Jun 2011, 23:50
Noob
Thanks a ton man.
Top
 Profile
PostPosted: 26 Jun 2011, 09:17
Noob
Hi MaLd0n,
I'm brand new to the Hackintosh scene and have ordered some hardware today using a "Gigabyte GA-Z68MA-D2H-B3" Z68 motherboard.
I saw you have an OSX version of AutoPatcher for Z68, but no Windows version. How do I extract my DSDT in OSX correctly to patch, as if I understand correctly (which I may not!!) to get into OSX I will need to use a DSDT from somewhere and when extracting my data using Auto-Patcher, it will use the running DSDT as the basis for the extract, and will therefore not be a perfect extract.
Apologies if I am misunderstanding, and thank you for all the fantastic work you are doing.
Edit: would the best option be to install Win7 first and use Everest/AIDA64 to generate an acpi_dsdt.bin and run that through Auto-Patcher?
Edit 2: Might have misunderstood - do I just need to run the z68 version of AutoPatcher on first install of Snow Leopard prior to running MultiBeast?
Mark
_________________
Gigabyte GA-Z68MA-D2H-B3 | Sandy Bridge Core i5 2500K 3.3GHz |
XFX HD 6870 Black Edition Radeon - HD-687A-ZDBC | Corsair Vengeance 8GB |
OCZ Agility 3 120Gb SSD | Sony AD-7260S-0B 24x DVD±R
Top
 Profile
PostPosted: 26 Jun 2011, 16:49
Staff
follow it
viewtopic.php?f=16&t=135
use HackBootV6
_________________
Top
 Profile
PostPosted: 26 Jun 2011, 17:38
Noob
MaLd0n wrote:
follow it
use HackBootV6
Thanks MaLd0n. Will give it a try when the hardware arrives on Tuesday.
_________________
Top
 Profile
PostPosted: 27 Jun 2011, 03:08
Staff
jky3b wrote:
Can you make a dsdt for my board thanks.
Mobo?
_________________
Top
 Profile
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
Search for:
Jump to:
