olarila.com
Mac OS X x86 - Hackintosh
It is currently 22 May 2013, 07:45
Post new topic Reply to topic  [ 398 posts ]  Go to page Previous  1 ... 36, 37, 38, 39, 40  Next
Author Message
PostPosted: 22 Jan 2012, 01:45
Noob
Hi, Im Walter from Argentina, I'm trying to use the DSDT patch for the Dell Optiplex 780 with the application auto DSDT Partch. What I would like to know on time, is for BIOS version works.
I would appreciate your help. From already thank you very much and excuse my English.
Top
 Profile
PostPosted: 22 Jan 2012, 15:13
Staff
hi
any time u do a bios upgrade, must generate new dsdt of them
and use this
viewtopic.php?f=19&t=634
_________________
PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI - ML 10.8.3/ Lion 10.7.5/SL 10.6.8/W 8 Pro x64/Ubuntu 12.04 - Quadriboot GUID - My OS X Files - join me at irc.freenode.net/#olarila
Top
 Profile
PostPosted: 22 Jan 2012, 16:48
Noob
artur-pt wrote:
hi
and use this
Tanks!!
Top
 Profile
PostPosted: 04 Feb 2012, 01:53
Noob
I've created a dsdt for my board Gigabyte EP35-DS3P using GA EP35-DS3P.txt and ALC 889a.txt. With the compiled dsdt.aml I am successfully running Lion 10.7 Vanilla with FakeSMC and for the sound stuff I use ALC8xxHDA/AppleHDA Rollback. No other kexts was necessary.
I still have sleep issues tough:
1. My PC goes to sleep properly but after waking up I get kernel panic.
2. I've tried using NullCPUPowermanagement - the PC goes to sleep and never wakes up again...
3. I tried to add patches LPC ICH9.txt + New HPET.txt and I still get kernel panic.
Would you please help me with further patching?
Top
 Profile
PostPosted: 04 Feb 2012, 02:15
Noob
I've attached some info on the panic.
Top
 Profile
PostPosted: 04 Feb 2012, 03:22
iGenius
Quote:
BSD process name corresponding to current thread: iCal Helper
I don't think it's DSDT related, there are reports about it even on real Macs
https://discussions.apple.com/thread/26 ... 5&tstart=0
Have you tried without the rollback audio kexts?
_________________
Top
 Profile
PostPosted: 04 Feb 2012, 10:09
Noob
Good job Cassio! Thank you very much.
1.
I don't know how to revert from AppleHDA rollback (maybe I should have backed up the original first me noob or how?)...
2.
Combo Update 10.7 -> 10.7.3
This replaced the AppleHDA rollback to original I suppose.
Reboot.
Sleep and wake up works :)))))
No sound. :(
3.
Reapplied Realtek ALC8xx.
Reboot.
No sound.
(sleep+wake still works)
4.
Build new dsdt.aml
I applied
GA EP35-DS3P.txt
ALC889A.txt
ALC 889a.txt
5.
Reboot with new dsdt.aml
Still no sound
Applying AppleHDA Rollback (MultiBeast)
(still forget to back the original up - hmm)
6.
Reboot.
Sound is up :)))))
Sleep.
(crossing fingers)
(waking...)
Wake.
no kernel panic :))))))))) It works !
I'd like to ask which patch should I add for my Gigabyte EP35-DS3P rev 2.1 F6 and HDEF ALC889a onboard audio for audio?
- ALC 889a.txt (under HDEF Gigabyte)
- ALC889A.txt (under Misc)
I tried if I add either of them or both of them - so in all cases - the onboard soundcard works under Lion 10.7-10.7.3 but I still have to add ALC8xxHDA and AppleHDA Rollback with MultiBeast.
Is ALC 889a.txt (HDEF Gigabyte section) is enough for my dsdt.aml?
(original DSDT is 2-3 posts up attached as send.zip to my post)
Top
 Profile
PostPosted: 04 Feb 2012, 16:30
iGenius
You will always need ALC8xxHDA+AppleHDA rollback, or a patched Lion AppleHDA.
In DSDT part, the important is that layout-id coincides with LayoutID in AppleHDA, see here viewtopic.php?f=19&t=634
_________________
Top
 Profile
PostPosted: 04 Feb 2012, 17:34
Noob
The layout ID is "0x75, 0x03, 0x00, 0x00" for my soundcard.
I'm already using a modified GA EP35-DS3P.txt by modifing the layout ID part of that patch (I've read about this somewhere).
Code:
into device label HDEF insert
begin
    {\n
        Store (Package (0x04)\n
            {\n
                "layout-id", \n
                Buffer (0x04)\n
                {\n
                    0x75, 0x03, 0x00, 0x00\n
                }, \n
                "PinConfigurations", \n
                Buffer (Zero) {}\n
            }, Local0)\n
        Return (Local0)\n
end;
However both the "Gigabyte HDEF" and the "Misc" alc 889a patch already contains this layout id.
Does it matter which one I use in my DSDT?
Top
 Profile
PostPosted: 04 Feb 2012, 18:09
iGenius
If you edited GA EP35-DS3P.txt to fit your needs, you don't need another HDEF patch. I would use the one from "Gigabyte HDEF" since the mobo is Gigabyte.
_________________
Top
 Profile
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
