olarila.com
Mac OS X x86 - Hackintosh
It is currently 21 May 2013, 07:46
Post new topic Reply to topic  [ 398 posts ]  Go to page Previous  1 ... 35, 36, 37, 38, 39, 40  Next
Author Message
PostPosted: 04 Nov 2011, 04:50
iGenius
It's not gone, just moved viewtopic.php?f=19&t=385
Check the link I posted there (speedstepper).
_________________
Top
 Profile
PostPosted: 04 Nov 2011, 05:38
GeekInTraining
ok, thanks
Top
 Profile
PostPosted: 07 Nov 2011, 17:01
Noob
Acer Aspire 5940G
CPUID:Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz
BIOS Insyde Version V1.07
Table Description
APIC: Multiple APIC Description Table
ASF!: Alert Standard Format Table
ASPT: ACPI System Performance Tuning Table
BOOT: Simple Boot Flag Table
DMAR: DMA Remapping Table
DSDT: Differentiated System Description Table
FACP: Fixed ACPI Description Table
FACS: Firmware ACPI Control Structure
HPET: IA-PC High Precision Event Timer Table
MCFG: Memory Mapped Configuration Space Base Address Description Table
RSD PTR: Root System Description Pointer
RSDT: Root System Description Table
SLIC: Software Licensing Description Table
SSDT: Secondary System Description Table
WDRT: Watchdog Resource Table
XSDT: Extended System Description Table
Can you make some DSDT for that board?
So much Thanks on advice!
Top
 Profile
PostPosted: 02 Dec 2011, 11:14
Noob
Dear Mald0n,
I'm trying to use a dsdt generated from you for a slightly different thinkpad x121e and I'm having a few problems. Maybe it's because configuration is a little bit different.
Could you be so kind to generate a dsdt for me?
Here the send_me.zip generated from inside Lion after booting without any custom dsdt.
Thanks a lot, it would be very helpful.
Pippolino
Top
 Profile
PostPosted: 07 Dec 2011, 05:29
Noob
Hi MaLd0n, can you please help me with DSDT on GigByte G41m-Combo MOBO?
http://www.gigabyte.com/products/produc ... id=3505#ov
I appreciate it more than I can express. I'm setting this up for my son and he is so excited, but I have yet to get it working properly without a good DSDT.
Thank you so much in advance!
Top
 Profile
PostPosted: 13 Dec 2011, 14:22
Noob
Hi Mald0n,
can you please make a DSDT for my mobo?
Asus maximus iv extreme
intel core i7 2600k
Evga GTX 580
Saludos :D
Top
 Profile
PostPosted: 15 Dec 2011, 22:39
Noob
Hi there,
Thank's for the good work.
I have a Compaq C762NR laptop - 10.6.8 OS X,
Intel Core 2 Duo T5550
GMA X3100
ICH8
Conexant HDA
almost perfect run with /E/E - FakeSMC and VooDooHDA in /S/L/E without DSDT.
But the machine runs hot and when close the Lid, did not sleep.
Can you make some patches to the DSDT for that problems?
I extracted DSDT from OS X.
Top
 Profile
PostPosted: 15 Dec 2011, 23:31
Noob
Any possibility of this one?
Top
 Profile
PostPosted: 11 Jan 2012, 07:04
Noob
is there any way I could get a dsdt for a gateway nv53
Top
 Profile
PostPosted: 18 Jan 2012, 04:01
Noob
Hi MaLd0n
can you help me edit my hp dv2922tx DSDT, been trying it with no success,
as attach is the original that extracted from the source
i'm installing snow leopard 10.6.8 on dv 2922tx
power not cut off when lid closed.
Marvel yukon conflict with Bluetooth integrated Wifi ( BCM4312 )
Alps Touchpad n keyboard not work as i need usb ps2 mouse and keyboard
btw here are the quick specs of the hardware from hp websites
-Intel Core 2 Duo processor T5750 (2.0 GHz)
-250GB (5400RPM) Hard Drive
-3GB DDR2 SDRAM
-LightScribe Super Multi 8X DVD±RW with Double Layer Support
-HP 1.3MP Webcam will work with some of 3rd party software
-nVidia GeForce 8400M GS with 128MB DDR dedicated graphics memory - natively supported
-802.11b/g WLAN and Bluetooth - it will detect using io80211Family but ethernet will not work
-Ethernet - on OSX detect as MarvelYukon using IONetworkingFamily but BCM4312
-5 in 1 Digital Media Reader - Ricoh
-Express Card/54PC Card Slot - not detected
-Expansion Port 3 - not detected
-Firewire - Natively supported
thanks in advanced
Top
 Profile
Users browsing this forum: Google [Bot] and 2 guests
Search for:
Jump to:
