DSDT patch requests
Re: DSDT patch requests
Postby artur-pt » 02 Jun 2016, 08:27
u can post other links ..
if u use a patched dsdt .. don't repeat in clover dsdt fix .. disable all
and after boot with the dsdt .. post a ioregisterexplorer ..
http://www.insanelymac.com/forum/topic/ ... -for-lion/
that is how to patch ur bat status
after u can test .. and test again .. don't expect 1ª time and all work
artur-pt
Staff
Postby menelkir » 02 Jun 2016, 12:18
artur-pt wrote:hello
Thanks.
Ive posted what works and what not here here and here.
I'm really out of luck with this notebook. I've disabled everything related to patching DSDT and kernel, and a couple of things still don't work. I've tried to diminish the kexts in /Library/Extensions, leaving only FakeSMC and nothing.
Perhaps it's my DSDT.aml? I've extracted using Clover, maybe clover did something wrong when extracted this one (I don't know if this is even possible)? I'm out of options right now. :shock:
This is my actual config.plist, it's booting ok without any major problems (disregard the known hardware issues).
Update: I had some personal issues IRL, I'll do the ioreg later and attach in this post.
After some fightings with my notebook, I realized this notebook have efi (don't know how or why, because BIOS doesnt have a thing saying about EFI, but I was able to enter in EFI Boot Manager). So after reading a lot of stuff, I've tried to patch myself a DSDT (I didn't want to bother with another request and since the last one will not works for me, as now isn't in legacy mode anymore (yes, I've tried)), specially because I want to understand how it works, and I was partially successful. So.. I had some warnings, 0 errors and able to boot into my system. Here is my own patched DSDT, and the entire drop from clover to examine.
As you requested, here's my IOREG
Notebook: Toshiba Qosmio X505-Q855 | i5-450M 2.5Ghz | 8Gb DDR3 | Nvidia GeForce GTS 360M - 1Gb GDDR5 | 1680x945
Desktop: Asus P8H61-M LX2 R2.0 | i5-3470 3.2Ghz | 8Gb DDR3 | Nvidia GeForce GTX650 - 2Gb GDDR5 | 1920x1080
menelkir
CPU: i5-3470 3.2Ghz
Motherboard: Asus P8H61-M LX2 R2.0
GPU: Nvidia GeForce GTX650 - 2Gb
Postby telepati » 08 Jun 2016, 22:02
Hi Artur, My ASUS Z170-A DSDT giving some errors and need to be fix. Could you help me with that? I removed DSDT with F4 command when Clover boot screen come. I attached it.
telepati
CPU: i7 6700K
Motherboard: ASUS Z170-A
GPU: NVIDIA GTX 660
Postby artur-pt » 09 Jun 2016, 06:39
telepati wrote:Hi Artur, My ASUS Z170-A DSDT giving some errors and need to be fix. Could you help me with that? I removed DSDT with F4 command when Clover boot screen come. I attached it.
there u go , now u do what u want with it
artur-pt
Staff
Postby telepati » 09 Jun 2016, 18:29
Thank you man as always you are perfect.
telepati
CPU: i7 6700K
GPU: NVIDIA GTX 660
Postby MaCXyLo » 11 Jun 2016, 20:54
Hi,
try to decompile at the moment my dsdt table.
One Method is unresolved...
-Motherboard Manufacturer and Model : Dell Vostro 3350 - 0M516T
-Bios Revision : A10
-Bios Type : American Megatrends Inc. (AMI)
-Bios Link : http://downloads.dell.com/FOLDER02130581M/1/3350A10.EXE
The commands i executed to extract the ACPI:
sudo acpidump > acpi.dat
acpixtract -a acpi.dat
refs.txt
Code: Select all
External(MDBG, MethodObj, 1)
External(_GPE.MMTB, MethodObj, 0)
External(_SB_.PCI0.LPCB.H_EC.ECWT, MethodObj, 2)
External(_SB_.PCI0.LPCB.H_EC.ECRD, MethodObj, 1)
External(_SB_.PCI0.PEG0.PEGP.SGPO, MethodObj, 2)
External(_SB.PCI0.GFX0.DD02._BCM, MethodObj, 1)
External(_SB.PCI0.SAT0.SDSM, MethodObj, 4)
External(_SB.PCI0.SAT1.SDSM, MethodObj, 4)
External(_GPE.VHOV, MethodObj, 3)
Code: Select all
iasl -fe refs.txt -e ssdt*.dat -da -dl dsdt.dat
Intel ACPI Component Architecture
ASL+ Optimizing Compiler version 20160108-64
Copyright (c) 2000 - 2016 Intel Corporation
Input file dsdt.dat, Length 0x9B62 (39778) bytes
ACPI: DSDT 0x0000000000000000 009B62 (v02 DELL   WN09     00000000 INTL 20051117)
External object resolution file        ssdt8.dat
Input file ssdt8.dat, Length 0x119 (281) bytes
ACPI: SSDT 0x0000000000000000 000119 (v01 PmRef  ApCst    00003000 INTL 20051117)
Pass 1 parse of [SSDT]
Pass 2 parse of [SSDT]
External object resolution file        ssdt7.dat
Input file ssdt7.dat, Length 0x303 (771) bytes
ACPI: SSDT 0x0000000000000000 000303 (v01 PmRef  ApIst    00003000 INTL 20051117)
External object resolution file        ssdt6.dat
Input file ssdt6.dat, Length 0x64F (1615) bytes
ACPI: SSDT 0x0000000000000000 00064F (v01 PmRef  Cpu0Cst  00003001 INTL 20051117)
External object resolution file        ssdt5.dat
Input file ssdt5.dat, Length 0xDF7 (3575) bytes
ACPI: SSDT 0x0000000000000000 000DF7 (v01 AmdRef AmdTabl  00001000 INTL 20091112)
External object resolution file        ssdt4.dat
Input file ssdt4.dat, Length 0xD80 (3456) bytes
ACPI: SSDT 0x0000000000000000 000D80 (v01 SgRef  SgTabl   00001000 INTL 20091112)
External object resolution file        ssdt3.dat
Input file ssdt3.dat, Length 0x996 (2454) bytes
ACPI: SSDT 0x0000000000000000 000996 (v01 PmRef  CpuPm    00003000 INTL 20051117)
External object resolution file        ssdt2.dat
Input file ssdt2.dat, Length 0x780 (1920) bytes
ACPI: SSDT 0x0000000000000000 000780 (v01 PmRef  Cpu0Ist  00003000 INTL 20051117)
External object resolution file        ssdt1.dat
Input file ssdt1.dat, Length 0x4B0 (1200) bytes
ACPI: SSDT 0x0000000000000000 0004B0 (v01 TrmRef PtidDevc 00001000 INTL 20091112)
refs.txt: Importing method external (1 arguments) MDBG
refs.txt: Importing method external (0 arguments) _GPE.MMTB
refs.txt: Importing method external (2 arguments) _SB_.PCI0.LPCB.H_EC.ECWT
refs.txt: Importing method external (1 arguments) _SB_.PCI0.LPCB.H_EC.ECRD
refs.txt: Importing method external (2 arguments) _SB_.PCI0.PEG0.PEGP.SGPO
refs.txt: Importing method external (1 arguments) _SB.PCI0.GFX0.DD02._BCM
refs.txt: Importing method external (4 arguments) _SB.PCI0.SAT0.SDSM
refs.txt: Importing method external (4 arguments) _SB.PCI0.SAT1.SDSM
refs.txt: Importing method external (3 arguments) _GPE.VHOV
ACPI Exception: AE_ALREADY_EXISTS, while adding external to namespace [_SB_.PCI0.PEG0.PEGP.SGPO] (20160108/dmextern-931)
refs.txt: Imported 9 external method definitions
Pass 1 parse of [DSDT]
Pass 2 parse of [DSDT]
Parsing Deferred Opcodes (Methods/Buffers/Packages/Regions)
Parsing completed
Found 14 external control methods, reparsing with new information
Parsing completed
Disassembly completed
ASL Output:    dsdt.dsl - 355521 bytes
iASL Warning: There were 14 external control methods found during
disassembly, but only 13 were resolved (1 unresolved). Additional
ACPI tables may be required to properly disassemble the code. The
resulting disassembler output file may not compile because the
disassembler did not know how many arguments to assign to the
unresolved methods. Note: SSDTs can be dynamically loaded at
runtime and may or may not be available via the host OS.
If necessary, the -fe option can be used to specify a file containing
control method external declarations with the associated method
argument counts. Each line of the file must be of the form:
    External (<method pathname>, MethodObj, <argument count>)
Invocation:
    iasl -fe refs.txt -d dsdt.aml
The facp table makes some problems, if i try to decompile it together with the other files.
I know, in the guides that are written down stands only to use ssdt*.dat and dsdt.dat.
Code: Select all
ACPI: FACP 0x0000000000000000 0000F4 (v04 DELL   WN09     01072009 AMI  00010013)
Pass 1 parse of [FACP]
ACPI Warning: Invalid character(s) in name (0x00000450), repaired: [P***] (20160108/utstring-311)
ACPI Warning: Invalid character(s) in name (0x20000004), repaired: [****] (20160108/utstring-311)
ACPI Warning: Invalid character(s) in name (0x00000004), repaired: [****] (20160108/utstring-311)
ACPI Error: ACPI Warning: Invalid character(s) in name (0x00000004), repaired: [****] (20160108/utstring-311)
[****] Namespace lookup failure, AE_ALREADY_EXISTS (20160108/dswload-390)
ACPI Exception: AE_ALREADY_EXISTS, During name lookup/catalog (20160108/psobject-238)
Could not parse external ACPI tables, AE_ALREADY_EXISTS
don't know, if it's related with the missing method.
Howto decompile my dsdt table correctly?
Compiler shows following stuff:
Code: Select all
iasl -tc dsdt.dsl
dsdt.dsl   2525:             Method (_OSC, 4, NotSerialized)  // _OSC: Operating System Capabilities
Remark   2120 -                        ^ Control Method should be made Serialized (due to creation of named objects within)
dsdt.dsl   4932:             Method (_SDD, 1, NotSerialized)  // _SDD: Set Device Data
dsdt.dsl   5042:         Method (_REG, 2, NotSerialized)  // _REG: Region Availability
Warning  3079 -                    ^ _REG has no corresponding Operation Region
dsdt.dsl   5137:         Method (SPTS, 1, NotSerialized)
Remark   2146 -                    ^ Method Argument is never used (Arg0)
dsdt.dsl   5143:         Method (SWAK, 1, NotSerialized)
dsdt.dsl   5258:     Method (UXDV, 1, NotSerialized)
dsdt.dsl   5261:         Name (_T_0, Zero)  // _T_x: Emitted by ASL Compiler
Remark   2011 -                  ^ Use of compiler reserved name (_T_0)
dsdt.dsl   5299:     Method (RRIO, 4, NotSerialized)
Remark   2146 -                ^ Method Argument is never used (Arg3)
dsdt.dsl   5301:         Name (_T_0, Zero)  // _T_x: Emitted by ASL Compiler
dsdt.dsl   5506:     Method (RDMA, 3, NotSerialized)
Remark   2146 -                ^ Method Argument is never used (Arg1)
Remark   2146 -                ^ Method Argument is never used (Arg2)
dsdt.dsl   5512:         Method (NPTS, 1, NotSerialized)
dsdt.dsl   5516:         Method (NWAK, 1, NotSerialized)
dsdt.dsl   5587:             Method (_DOD, 0, NotSerialized)  // _DOD: Display Output Devices
dsdt.dsl   7009:                     Return (Zero)
Error    6105 -                                ^ Invalid object type for reserved name (_CRS: found Integer, Buffer required)
dsdt.dsl   7315:             If (CondRefOf (_OSI, Local0))
Warning  3144 -    Method Local is set but never used ^  (Local0)
dsdt.dsl   7722:             Method (_DSM, 4, NotSerialized)  // _DSM: Device-Specific Method
dsdt.dsl   7726:                     Name (_T_0, Zero)  // _T_x: Emitted by ASL Compiler
dsdt.dsl   7730:                         Name (_T_1, Zero)  // _T_x: Emitted by ASL Compiler
Remark   2011 -    Use of compiler reserved name ^  (_T_1)
dsdt.dsl   7910:                         PLD_Revision       = 0x0,
Error    6105 -                                    ^ Invalid object type for reserved name (_PLD: found Buffer, Package required)
dsdt.dsl   7962:                             PLD_Revision       = 0x0,
Error    6105 -  Invalid object type for reserved name ^  (_PLD: found Buffer, Package required)
dsdt.dsl   8001:                             PLD_Revision       = 0x0,
dsdt.dsl   8090:                         PLD_Revision       = 0x0,
dsdt.dsl   8127:                             PLD_Revision       = 0x0,
dsdt.dsl   8171:                             PLD_Revision       = 0x0,
dsdt.dsl   8210:                             PLD_Revision       = 0x0,
dsdt.dsl   8249:                             PLD_Revision       = 0x0,
dsdt.dsl   8288:                             PLD_Revision       = 0x0,
dsdt.dsl   8982:     Method (SX45, 0, NotSerialized)
Warning  3115 -                ^ Not all control paths return a value (SX45)
dsdt.dsl   9011:     Method (STRE, 2, NotSerialized)
dsdt.dsl   9039:             If (CondRefOf (_OSI, Local0))
dsdt.dsl   9104:     Method (DISP, 1, NotSerialized)
dsdt.dsl   9108:     Method (NEVT, 0, NotSerialized)
dsdt.dsl   9142:             Name (_T_0, Zero)  // _T_x: Emitted by ASL Compiler
dsdt.dsl   9205:         Store (GPUF, Local1)
Warning  3144 -                           ^ Method Local is set but never used (Local1)
dsdt.dsl   9274:             Store (GPUF, Local1)
dsdt.dsl   9400:         Store (GPUF, Local1)
dsdt.dsl   9465:     Method (EGB0, 3, NotSerialized)
dsdt.dsl   9479:     Method (EGB1, 1, NotSerialized)
dsdt.dsl   9486:         CreateByteField (BBSN, Zero, SN00)
Remark   2089 -                Object is not referenced ^  (Name is within method [EGB1])
dsdt.dsl   9488:         CreateByteField (BBSN, 0x03, SN03)
dsdt.dsl   9502:     Method (EGB2, 1, NotSerialized)
dsdt.dsl   9527:     Method (EGB3, 1, NotSerialized)
dsdt.dsl   9530:         CreateWordField (BBOI, Zero, OI00)
Remark   2089 -                Object is not referenced ^  (Name is within method [EGB3])
dsdt.dsl   9531:         CreateByteField (BBOI, 0x02, OI02)
dsdt.dsl   9622:     Method (ECG6, 2, NotSerialized)
dsdt.dsl   9626:         CreateByteField (BBST, One, BF01)
Remark   2089 -               Object is not referenced ^  (Name is within method [ECG6])
dsdt.dsl   9674:     Method (ECG9, 2, NotSerialized)
dsdt.dsl   9677:         CreateByteField (BBI1, Zero, BI00)
Remark   2089 -                Object is not referenced ^  (Name is within method [ECG9])
dsdt.dsl   9685:         CreateByteField (BBI2, 0x03, BI07)
dsdt.dsl   9848:             Method (_BIF, 0, NotSerialized)  // _BIF: Battery Information
dsdt.dsl   9855:             Method (_BST, 0, NotSerialized)  // _BST: Battery Status
dsdt.dsl   9937:             Name (_HID, "pnp0c14")  // _HID: Hardware ID
Error    6136 -                                 ^ Non-hex letters must be upper case (pnp0c14)
dsdt.dsl   9993:             Method (WCAA, 1, NotSerialized)
dsdt.dsl  10019:             Method (WSAA, 2, NotSerialized)
dsdt.dsl  10029:             Method (WMBA, 3, NotSerialized)
dsdt.dsl  10369:         Method (PHWM, 2, NotSerialized)
dsdt.dsl  10642:         Method (_REG, 2, NotSerialized)  // _REG: Region Availability
dsdt.dsl  10684:                 Return (BUF2) /* \_SB_.PCI0.A_CC.BUF2 */
Warning  3104 -                            ^ Reserved method should not return a value (_SRS)
ASL Input:     dsdt.dsl - 10754 lines, 355521 bytes, 4121 keywords
Hex Dump:      dsdt.hex - 373130 bytes
Compilation complete. 11 Errors, 9 Warnings, 45 Remarks, 217 Optimizations
MaCXyLo
CPU: Intel Core i5 2410M
Motherboard: 0M516T
GPU: Radeon HD 7400M Series
Postby artur-pt » 12 Jun 2016, 00:20
@MaCXyLo
this ur dsdt without any errors
use acpi 4.0
dsdt.aml.zip
now u do what u want with it .. but for that u must read ..
artur-pt
Staff
Postby MaCXyLo » 12 Jun 2016, 00:29
thank you very much!! :)))
Kind Regards,
MaCXyLo
MaCXyLo
Motherboard: 0M516T
Postby MaCXyLo » 18 Jun 2016, 18:56
Dear artur-pt,
i compiled the fixed dsdt table directly into the linux kernel.
if i adjust the brightness the notebook freezes sometimes.... (not happened with the unpatched dsdt...)
tried 2 common kernel parameter to fix this problem:
acpi_enforce_resources=lax
processor.nocst=1
happens on the patched/unpatched dsdt:
dmesg | grep "ACPI Warning"
[ 15.615732] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20160108/utaddress-255)
[ 15.615745] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160108/utaddress-255)
[ 15.615748] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20160108/utaddress-255)
[ 15.615753] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160108/utaddress-255)
[ 15.615756] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20160108/utaddress-255)
[ 15.615760] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160108/utaddress-255)
[ 15.615762] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20160108/utaddress-255)
happens only on the patched dsdt:
dmesg | grep "wmi"
[ 1.567310] wmi: Failed to parse WDG method
[ 1.567711] wmi: Mapper loaded
This is the log of the firmware test suite from ubuntu (unpatched dsdt):
https://bugs.launchpad.net/ubuntu/+bug/ ... CPI.tar.gz
MaCXyLo
Motherboard: 0M516T
Postby pooriansari23 » 18 Jun 2016, 20:05
I need my dsdt to be patched.
this is the file you need
I want to fix Audio ,backlight brightness , wireless and battery indicator besides intel power management.
thank you
pooriansari23
CPU: corei7 4500 u
Motherboard: laptop asus x550ld intel
GPU: nvidia 820m
PreviousNext
Return to DSDT
Users browsing this forum: Google [Bot] and 3 guests
