DSDT patch requests
jori
CPU: 5820k
Motherboard: ASUS Sabertooth X99
GPU: MSI Radeon RX VEGA 56 Air Bo
DSDT patch requests
Post by jori » 13 Oct 2019, 09:26
13 Oct 2019, 03:09
jori, first try with only BrcmBluetoothInjector.kext
Still no joy unfortunately. Soon as I place the DSDT in, bluetooth stops, with and without any combination of the kexts. I re-done RunMe and attached, everything is working in this zip, bluetooth / wifi all good, but no DSDT is patched.
ahmedgamal09
CPU: core i3-6006u
Motherboard: Unknown
GPU: Intel hd520
DSDT patch requests
Post by ahmedgamal09 » 13 Oct 2019, 10:01
13 Oct 2019, 03:09
super_qb, DSDT.aml.zip
inject audio via cloveer, check my signature, useful links
idk about ur gpu
Added in 4 minutes 25 seconds:
ahmedgamal09, DSDT.aml.zip
the the trackpad works fine but detected as mouse and the brightness works but the battary status doesn't work at all
and if i put the acpibatterymanager.kext in kext folder it show me 0% in battery status and if i use run me.app it give me kernel log with 700mb in size can you help me
jjpower80
CPU: i5 4440 Haswell
Motherboard: Asus B85M-G 16Gb DDR3 1600Mhz
GPU: Radeon RX560 4GB
DSDT patch requests
Post by jjpower80 » 13 Oct 2019, 10:05
Thanks Maldon and Team :guitar
Paulens
CPU: HexaCore Intel Core i7-9850H
Motherboard: Lenovo ThinkPad P53
GPU: Intel(R) UHD 630, NVIDIA T2000
DSDT patch requests
Post by Paulens » 13 Oct 2019, 11:23
13 Oct 2019, 03:58
Paulens, first try use it
<key>PciRoot(0)/Pci(0x02,0)</key>
			<dict>
				<key>disable-external-gpu</key>
				<data>
				AQAAAA==
				</data>
				<key>framebuffer-fbmem</key>
				<data>
				AACQAA==
				</data>
				<integer>1</integer>
				<data>
				AAAwAQ==
				</data>
			</dict>
MaLd0n, Ok, just tried, looks to be same kernel panic. Used this CLOVER with your suggested settings added - [External Link Removed for Guests]
Video (made it slow motion):
Also found this one - [External Link Removed for Guests], do you think its relevant in my situation?
BallCS
CPU: i9 9900k
Motherboard: z390 aorus pro wifi
GPU: rx580
DSDT patch requests
Post by BallCS » 13 Oct 2019, 12:13
i can't shutdown and restart
berserk
CPU: core i3 m330
Motherboard: toshiba l500
GPU: mobility ati 4650
DSDT patch requests
Post by berserk » 13 Oct 2019, 12:59
12 Oct 2019, 01:50
hi MaLd0n
Thanks for the help, thank you very much
Please help me to fix laptop parts , dsdt and choice clover folder
Thank you
Hi can i know what clover for my chipset whiskey lake
sitisence
CPU: Xeon E5-2670
Motherboard: Huanan X79
GPU: RX570
DSDT patch requests
Post by sitisence » 13 Oct 2019, 13:29
Hi again MaLd0n
Thanks for the help.
This is my laptop Send_me 's file
rusovich
CPU: i5
Motherboard: gy z97 hd3
GPU: gt 640
DSDT patch requests
Post by rusovich » 13 Oct 2019, 13:32
ossssii
CPU: i7-2600k
Motherboard: Asrock Z77 Pro4-M
GPU: Geforce GTX 680 (flashed)
DSDT patch requests
Post by ossssii » 13 Oct 2019, 13:55
Hi MaLd0n and Team,
SendMe Folder is attached, would appreciate an improved DSDT file.
Thank you in advance!
Edit: Just had a freeze, i did a new Run Me - maybe you can find something?
Tullaphat
CPU: Intel i7 6700
Motherboard: MSI Z170A M3
GPU: GTX 1080Ti
DSDT patch requests
Post by Tullaphat » 13 Oct 2019, 15:38
This is my files.
actually my Mac is work fine (no problem found yet). I'm not sure I have to do this or not. :lol:
erpipas46
CPU: Asus
Motherboard: Asus
GPU: Nvidia Geforce
DSDT patch requests
Post by erpipas46 » 13 Oct 2019, 15:40
Send me iMac-de-NORBERTO.zip
Hola amigos,necesito mi parcheo, a la espera de ayudarme . Muchas gracias.
shafinonair
CPU: i5 7200U
Motherboard: intel
GPU: intel HD graphics 620 2gb
DSDT patch requests
Post by shafinonair » 13 Oct 2019, 16:15
hello Please help me to active my volume Hdmi port and card reader work
if possible wifi too
thanks
kobkob772
CPU: i5
Motherboard: -
GPU: hd 2000
DSDT patch requests
Post by kobkob772 » 13 Oct 2019, 16:59
Hello, I encountered a problem.
1. The screen cannot adjust the light.
2. Batteries do not show percent.
3. HDMi audio not working.
SAMSUNG ATIV BOOK 5 NP540U4E
totitok11
CPU: i7-7700HQ
Motherboard: Asus
GPU: IHD630
DSDT patch requests
Post by totitok11 » 13 Oct 2019, 18:25
Edit your(maldon) smbios from mbp14,3 to mbp 14,1 hdmi works. But i got imess error.
But still. I need hdmi audio and some tune from you, maldon. Thanks
Wizzard
CPU: Intel m3-7Y30
Motherboard: Teclast F6 Pro
GPU: Intel HD 615
DSDT patch requests
Post by Wizzard » 13 Oct 2019, 19:38
Maldon, thank you very much, but my system did not boot with that patch so I generated a new runme file
erroruser
CPU: i9 9900k
Motherboard: asus z390-a
GPU: Sapphire rx 5700 XT
DSDT patch requests
Post by erroruser » 13 Oct 2019, 20:27
13 Oct 2019, 05:26
Maybe I'm doing something wrong in activating my iCloud account. With Catalina as you know you start by going into settings and clicking on the sign in button and log in using Apple ID. At this point everything goes normally. Then I wait a few moments for everything to sort of catch up then I do as I did before, I click on iMessage and instead of it opening up a blank message, it asks me to sign in, as if its disconnected from the sign in process I just did. This has gotten me completely baffled.
UPDATE
Virtual NVRAM was not working (ROM and MLB failed with an iMessage Debugger script and ran an "NVRAM -p" command in terminal, showed no NVRAM) Installed EmuVariable, and it WORKED!! Thanks to Chris Batenchuk from FB Hackintosh group
:superman :superman :superman
Asus z390-A, i9 9900k, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, sapphire rx 590, fractal celcius s36
:superman :superman
SemoB
CPU: Core i7-8750H
Motherboard: Tongfang GK5CN6Z (Coffee Lake)
GPU: Intel UHD 630 & Nvidia GTX1060
DSDT patch requests
Post by SemoB » 13 Oct 2019, 23:58
Hi, I have just installed macOS Catalina on my laptop. Many things still don't work (like audio, battery, PS2 trackpad, Bluetooth, etc (I'm still working on getting everything working). I have run the RunMe app and attached below my Send Me output. I would appreciate a tailored DSDT. I'm happy to provide any further info as needed.
Thanks again.
DSDT patch requests
Post by MaLd0n » 14 Oct 2019, 01:44
hbp,
Added in 2 minutes 20 seconds:
Iron-phil, ur config is very wrong, use correct renames, reboot and extract new send_me
change GFX0 to IGPU
47465830
49475055
change HDAS to HDEF
48444153
48444546
change HECI to IMEI
48454349
494d4549
change SAT0 to SATA
53415430
53415441
Added in 4 minutes 4 seconds:
jori, check if work
Added in 42 seconds:
ahmedgamal09, check useful links in my signature, some patches is personal
Added in 2 minutes 55 seconds:
Paulens, patch is done in correct local? device/properties?
try with this folder for install
Added in 4 minutes 19 seconds:
BallCS,
Arquivo Comprimido.zip
use correct clover folder, serie 100/200/300
Added in 42 minutes 4 seconds:
berserk,
Added in 3 minutes 37 seconds:
sitisence,
Added in 3 minutes 44 seconds:
rusovich,
Added in 3 minutes 31 seconds:
ossssii,
use shikigva=60
Added in 3 minutes 36 seconds:
Tullaphat,
Added in 4 minutes 18 seconds:
erpipas46,
go to catalina
Added in 3 minutes 12 seconds:
shafinonair,
u need a connectors patch for hdmi
check what card reader u have
Added in 6 minutes :
kobkob772,
Added in 1 minute 9 seconds:
totitok11, the config looks good, what problem ur hack have?
Added in 2 minutes 11 seconds:
SemoB, use voodooi2c kexts
audio just inject via clover
BallCS
CPU: i9 9900k
GPU: rx580
DSDT patch requests
Post by BallCS » 14 Oct 2019, 02:15
Thank you very much.
adriteam
CPU: 6700HQ
Motherboard: Intel HM170 (Skylake PCH-H)
GPU: HD Graphics 530 and GTX 970M
DSDT patch requests
Post by adriteam » 14 Oct 2019, 03:36
Hello friends of Olarila.
I recently built my MSI GS40 with High Sierra following your steps.
The battery meter behaved strangely in High Sierra (suddenly it dropped from 39% to only 7%) and since the battery did not last long I decided to replace it.
My surprise is that the meter continues to behave strangely, so I have reinstalled my update BIOS. The problem persists and for this reason I come to ask you again for a DSDT for the new BIOS and the new hardware installed.
I attach my runme. Audio is work with VoodooHDA. Config.plist is very light configured for me. Thank you very much for your effort and support to debug my hackintosh. Sorry for my bad English. Greetings.
Return to “DSDT”
