olarila.com
Mac OS X x86 - Hackintosh
It is currently 19 Jun 2013, 07:16
Post new topic Reply to topic  [ 174 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 18  Next
Author Message
 Post subject: Re: ATI Graphics
PostPosted: 27 Jul 2012, 08:51
Staff
hi
try to play with the several families present in the kext
rename it one by one to the name u family
and insert in the dev id of u gpu
try first with cypress
_________________
PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI - ML 10.8.4/ Lion 10.7.5/SL 10.6.8/W 8 Pro x64/Ubuntu 12.04 - Quadriboot GUID - My OS X Files - join me at irc.freenode.net/#olarila
Top
 Profile
PostPosted: 27 Jul 2012, 13:40
Noob
Hello!
I would like to ask for a little help.
I have a "special-edition" HD5670 card. To be precise: VTX3D Radeon HD5670/1GB
System Information here:
As you can see it has a custom device id 68B9 which not the standard for HD5670 cards: They use 68D8 usually
This wasn't a problem for me in OSX 10.7.x cause I just added 0x68B91002 manually to my ATI5000Controller.kext repaired permissions and it worked perfectly with Hoolock personality added to org.chameleon.boot.plist
Now in 10.8 there's no info.plist in the ATI5000Controller.kext
I did researches and found info about the newly introduced AMDRadeonAccelerator.kext
I opened it up and edited its info.plst under the Juniper part and added the line 0x68B9 to it (I know 5670s use Redwood but GeekBench says it's a Juniper card)
So I added the line, repaired permissions booted up with GraphicsEnabler=Yes (I use ErmaC's latest boot loader).
With -v it boots the system but the screen stuck at showing the log. If I type in my password (blind - no GUI) and then I press CMD+Shift+3 it takes a screenshot(I can hear the sound) so it means the system boots up properly but it messes up something with the vga.
This is everything I could find out by myself.
Do you have any idea what should I do?
My system spec are:
Gigabyte H61M-D2-B3 (I'm using pre edited DSDT - works well)
Intel i3 2120 CPU
VTX3D 5670/1GB vga
4GB ram
Sorry for talking so much but I wanted to tell you everything and maybe it might help other people later in the future too.
Cheers,
Phantom
_________________
Motherboard: Gigabyte H61M-D2-B3 (Bios: F10) CPU: Intel i3-2120 3.30Ghz RAM: 1x4GB Kingston 1333Mhz
VGA: VTX3D HD5670/1GB (Juniper core. Device id: 68B9 - Has to add manually to ATI5000Controller and AMDAccellerator kexts.
Top
 Profile
PostPosted: 28 Jul 2012, 08:56
Noob
cool, thank you, artur-pt!
ATI Saphire HD 5450 1GB DDR3 (1002 68e1, subsys 174b 3000) QE/CI loss in ML solved: 68e1 is still present in ML ATI5000Controller.kext, but missing in AMDRadeonAccelerator.kext. Opened AMDRadeonAccelerator.kext/Content/Info.plist, found <string>0x68e01002</string> and extended into <string>0x68e01002 0x68e11002</string>, saved, rebooted, BOOOOM - translucent menu bar is back, DVD Player works.
HAPPY :)
Top
 Profile
PostPosted: 28 Jul 2012, 09:44
Staff
Quote:
"Phantomhive"
hi try the redwood family
are u sure that personality u are using is right, may also try anothers, in boot AtiConfig=
is only in ML that problems ?
_________________
Top
 Profile
PostPosted: 28 Jul 2012, 10:07
Noob
artur-pt wrote:
Quote:
"Phantomhive"
Hello!
Yes, only happens in MLion.
Lion works very well with same settings.
I think this is -maybe- a boot loader error cause if I put GraphicsEnabler to "No"
there is GUI but no qe/ci.
I'm sure about the Juniper but I will give Redwood a try again.
Will keep you posted.
Also Hoolock must be correct because it loads my card well.
No crash in DVD player and no ghost 2nd display.
Cheers,
Phantom
_________________
Top
 Profile
PostPosted: 11 Aug 2012, 18:03
Noob
Hello!
I own a XFX Radeon HD6870 HD-687A-ZDFC, which is a non-reference card (the one with two fans), and I can't get it to work under ML 10.8 .
I have a fresh install, and AMDRadeonAccelerator.kext seems to be the problem.
My device ID's are in all ATI6000Controller.kext, ATIFrambuffer.kext, AMDRadeonAccelerator.kext and ATISupport.kext. I have to delete AMDRadeonAccelerator.kext, otherwise I get a white screen, GPU freeze after bootup. The Systems boots up properly, I can connect via Network and also readout the system.log:
kernel[0]: AMDBartsGraphicsAccelerator: ** Device in slot: SLOT--1 **
kernel[0]: ** GPU Debug Info Start **
If I boot without AMDRadeonAccelerator.kext, the desktop comes up, but of course no QE/CI.
Do I have to edit the AMDRadeonAccelerator binary found in the kext to adress the fact that it is not a reference card? If so, can anybody point in the right direction?
Thank you very much for any ideas you might have.
-shinokubo
Top
 Profile
PostPosted: 12 Aug 2012, 22:53
Staff
try to follow this post
http://www.insanelymac.com/forum/index. ... pic=279100
_________________
Top
 Profile
PostPosted: 20 Aug 2012, 04:01
Noob
While waiting for solution to my problem on following thread viewtopic.php?f=27&t=1832&view=next I found your thread but cannot understand enough. Could you please help me why ATIRadeonX2000.kext is not loading? On Pg 2 of this thread you suggested someone to use legacyAGPM kext, is that applicable in my case too? If so do you have legacyAGPM kext for ATI Video card?
_________________
System: GIGABYTE GA-965P-DS3 (rev. 1.3) Socket 775
CPU: Intel Core 2 Duo E6300 Conroe 1.86GHz LGA 775 65W
Graphics: DIAMOND ATI Radeon™ HD 2600 XT 512MB GDDR2 PCIe
Top
 Profile
PostPosted: 21 Aug 2012, 03:41
Noob
Hi everybody.
I have a 4850 but I don't know how make this video card working on ML
I put the kext in S\L\E with kext utility but it still doesn't work.
It hangs on startup just a moment before the dock and the mouse cursor are loaded.
May you help me ?
Top
 Profile
PostPosted: 23 Aug 2012, 13:17
Noob
Hi. I have a Sony VAIO VPCEB1C5E with a ATI Mobility Radeon HD5470 512MB (System Info says it is "Manhattan") DeviceID:68e0 VendorID:1002. I am using Mountain Lion Final installed with Unibeast and using Chameleon v2.1svn r2033. i have edited the .plist as described in the tutorial but without any luck. when i boot with GraphicsEnabler=Yes i just get a black screen. All the kext files are loaded when i run kextstat, exept ATIFramebuffer. I am a little bit confused,perhaps i did something wrong, or i did not understand the tutorial. Can somebody help me with this? Thanx a lot guys.
P.S. This is my first try of a Hackintosh :P
Top
 Profile
Search for:
Jump to:
