olarila.com
Mac OS X x86 - Hackintosh
It is currently 20 May 2013, 08:55
Post new topic Reply to topic  [ 162 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 17  Next
Author Message
 Post subject: Re: ATI Graphics
PostPosted: 28 Feb 2012, 09:37
Noob
hi arthur. i'm still waiting for your kexts... for my ati 6870, thanks
_________________
osx lion 10.7.3 (multibeast 4.2.1 with dsdt)
gigabyte x58a ud7 rev 2 bios fc
i7 990x 3,47 ghz
noctua nh14
vapor-x 6870 1gb
Top
 Profile
PostPosted: 28 Feb 2012, 13:26
Staff
for what u say dont see any diference .. with and whitout them.
_________________
PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI - ML 10.8.3/ Lion 10.7.5/SL 10.6.8/W 8 Pro x64/Ubuntu 12.04 - Quadriboot GUID - My OS X Files - join me at irc.freenode.net/#olarila
Top
 Profile
PostPosted: 28 Feb 2012, 15:22
Noob
hello there..
difference between what??
how can i make this mac to use Intel Graphics only?
thx.. :)
_________________
ASUS A43SA - Intel Core™ i5 2430M/2410M - Ram 4GB - AMD Radeon HD 6730M 2GB - OS X Lion 10.7.2/Windows 7 x64
Top
 Profile
PostPosted: 02 Mar 2012, 10:59
Noob
when i use GraphicsEnabler,it turn into black screen..then i try to capture the screen because the system is still working.. it shows 1366 x 768 resolution.. i tried your tutorial about EDID but it still show the same black screen.. :( :(
need help please...
thanks...
_________________
Top
 Profile
PostPosted: 02 Mar 2012, 22:06
Staff
i dont see any info of u hardware
and is not easy to say anything about
update u profile
with u hardware signature, something like i have in the bottom of my answer
_________________
Top
 Profile
PostPosted: 03 Mar 2012, 05:39
Noob
i have updated my profile. :)
i try some of ATIConfig Framebuffer but it end with totally blackscreen (Juncus) or sometimes blackscreen with backlight still working (Muskgrass, Gibba, Kudzu)
thanks...
_________________
Top
 Profile
PostPosted: 04 Mar 2012, 13:38
Staff
u have a sandy cpu 2ª generation, the ati dont work, no solution for now, but the intel hd 3000 it works
use smbios macbookpro8,2
and see the kext in s/l/e
AppleIntelHD3000Graphics.kext
AppleIntelSNBGraphicsFB.kext
to see if u dev id is there (0x01168086 example) that is the correct format to insert u dev id
use this to see
viewtopic.php?f=18&t=63
_________________
Top
 Profile
PostPosted: 06 Mar 2012, 13:02
Noob
so is it impossible to have ati x1600 running snow leopard or is it possible
please help
_________________
laptop compal hel 80 c * nvidia ge force go 7600 * audio alc 883 not completly ok * intel core 2 duo t 5600 1.8
with all problems but runnin good THANKS TO ALL COMUNITY
Top
 Profile
PostPosted: 06 Mar 2012, 14:27
iGenius
If it is possible, probably is following instructions in first post.
Portuguese discussion: viewtopic.php?f=2&t=716
_________________
Top
 Profile
PostPosted: 18 May 2012, 16:12
Noob
Hi Guys... I'm in need of some help here with my PowerColor HD 5450 512MB.
My Setup:
OSX Lion
Installed by MyHack3.1
MB: P5KPL-AM
RAM: 2GB
HDD: 80GB SATA
The install when fine and boots into Lion with no problems, I have GE=Yes set and Lion see the graphics as a 5430M. I have full QE/CI but only the VGA port works.
I have checked the DID, they are already in the ATIRadeonX3000 and ATI5000Controller. The DID is 68E1 1002.
I read I have to delete all ATI kext but these 7, which I did ( this did not help!)
ATIRadeonX3000GA.plugin
ATIFramebuffer.kext
ATIRadeonX3000GLDriver.bundle
ATIRadeonX3000VADriver.bundle
ATI5000Controller.kext
ATIRadeonX3000.kext
ATISupport.kext
When I set GE=No it see it as a 5000 series, I can then get the VGA, DVI and HDMI to work. The don't like to be swapped between each other, but you can get all three working.
Can someone please walk me through what I need to do...
If there is any more info you need, just ask.
Thanks very much,
Ross
Top
 Profile
Users browsing this forum: Google Adsense [Bot] and 1 guest
Search for:
Jump to:
