olarila.com
Mac OS X x86 - Hackintosh
It is currently 20 Jun 2013, 07:10
Post new topic Reply to topic  [ 174 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 18  Next
Author Message
 Post subject: Re: ATI Graphics
PostPosted: 02 Feb 2012, 08:51
Noob
hi artur. this is my situation:
-hardware in signature
-mac osx lion 10.7.3
-multibeast 4.2.1 (so chimera 1.7)
system is stable (maybe as a real mac pro). cpu benchmark are impressive. the only issue is that my vapor x 6870 1gb has very poor scores in benchmarks. in cinebench it reaches 32 fps, versus the 50fps or more that other users, with the same graphic card, reach.
so, what's the problem?
i've tried using different smbios (mac pro 3,1:4,1;5,1 and even iMac 12,2, but nothing changes.
look at the pictures please:
_________________
osx lion 10.7.3 (multibeast 4.2.1 with dsdt)
gigabyte x58a ud7 rev 2 bios fc
i7 990x 3,47 ghz
noctua nh14
vapor-x 6870 1gb
Top
 Profile
PostPosted: 02 Feb 2012, 08:55
Noob
other pictures:
_________________
i7 990x 3,47 ghz
noctua nh14
vapor-x 6870 1gb
Top
 Profile
PostPosted: 09 Feb 2012, 14:38
Staff
in u case, i think must test legacyAGPM
viewtopic.php?f=18&t=715
_________________
PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI - ML 10.8.4/ Lion 10.7.5/SL 10.6.8/W 8 Pro x64/Ubuntu 12.04 - Quadriboot GUID - My OS X Files - join me at irc.freenode.net/#olarila
Top
 Profile
PostPosted: 11 Feb 2012, 09:11
Noob
thanks for the reply. but they spoke about nvidia card, not ati cards, as mine.
so what must i do?
_________________
i7 990x 3,47 ghz
noctua nh14
vapor-x 6870 1gb
Top
 Profile
PostPosted: 11 Feb 2012, 12:38
Staff
post here what smbios u are using and dev id of the ati card
for me to edit a legacy kext for you
_________________
Top
 Profile
PostPosted: 12 Feb 2012, 00:29
Noob
hi. i'm using macro 5,1 smbios. dev id of my vapor x is 0x1002 vendor and 0x6738 product.
i've tried kexts that you posted here http://www.insanelymac.com/forum/index. ... 74377&st=0 but without improvements of benchmarking.
thanks
_________________
i7 990x 3,47 ghz
noctua nh14
vapor-x 6870 1gb
Top
 Profile
PostPosted: 14 Feb 2012, 10:40
Noob
just updated bios, with fd13 version (beta bios), dsdt patched by madlon's dsdt auto patcher, now i reach 41 fps with cinebench (smbios 5,1)
_________________
i7 990x 3,47 ghz
noctua nh14
vapor-x 6870 1gb
Top
 Profile
PostPosted: 27 Feb 2012, 10:32
Noob
hello there..
i have ATI 6730m that i bought with Asus A43sa notebook..
everything works fine,just a problem with graphic card..
it's just showing the standard resolution (1024x768) display 3mb graphic.. :? :?
then i tried chimera with graphic enabler(because they said 6730m is supported by chimera)
but then i got a black screen.. the system is still working but a black screen..
really need help,please.. :)
_________________
ASUS A43SA - Intel Core™ i5 2430M/2410M - Ram 4GB - AMD Radeon HD 6730M 2GB - OS X Lion 10.7.2/Windows 7 x64
Top
 Profile
PostPosted: 27 Feb 2012, 11:55
Staff
what mac os x are u using ?
the problem is u have a sandy-bridge laptop with intel hd 3000 + ati graphics
no solution for now , to switch between cards
try to have intel hd 3000 working good, the ati card is know by the system, but not working...
in lion 10.7.2 first time support intel hd 3000
and wait for a solution to have switchable graphics between the 2 cards
_________________
Top
 Profile
PostPosted: 27 Feb 2012, 14:04
Noob
hello artur :)
i guess the switchable graphics is not working in ATI series (A43SA) because there is no option for switching the graphics in windows..it only works in nVidia Series (A43SV)
my friend use the nVidia series and it's working very well for Lion.. :cry:
if we can't use Intel Graphic in Windows,can we use it it Mac?
i am using Lion 10.7.2
how can i make this mac to use Intel Graphics only?
Thanks :D
_________________
Top
 Profile
Users browsing this forum: No registered users and 0 guests
Search for:
Jump to:
