VoodooHDA - common problems
Re: VoodooHDA - common problems
Postby nikitosina » 11 Feb 2012, 15:22
Cassio wrote:If the headphones jack is configured as auto-detect, try changing its default association, maybe it solves your problem.
Can you explain me how to do it?
nikitosina
Postby Cassio » 11 Feb 2012, 15:29
It's explained in the OP of this topic and there's a link to a more detailed example viewtopic.php?f=18&t=604
For example, if your config is
Code: Select all
nid 17 0x0221401f as 3 seq 0 Headphones Jack jack 1 loc 2 color Green misc 0
nid 18 0x01014010 as 1 seq 0 Line-out Jack jack 1 loc 1 color Green misc 0
change to
Code: Select all
nid 17 0x02214050 as 3 seq 0 Headphones Jack jack 1 loc 2 color Green misc 0
(default association 5 must not be used by other node, use first unused number)
Cassio
Senior
Postby nikitosina » 11 Feb 2012, 16:13
I'll try it. Thx
nikitosina
Postby mderksen » 23 Feb 2012, 08:49
When i use the (latest) VoodooHDA in this topic my laptop (Asus N53SV-SZ404V) my speakers looks like they gonna explode. A very hard noise. So i have to shutdown the laptop immediatly.
I also used a older version of VoodooHDA but i didn't had a prefpane with that one. The sound was not working with this older one so i want to try the prefpane settings in first post. That's why i want to try this version.
Do i have to patch my DSDT.aml for the sound? Or do i have to use an older VoodooHDA with prefpane? I patched my DSDT with DTGP, EHCI and IRQS.
mderksen
Postby Cassio » 23 Feb 2012, 11:52
Read about audio feedback in the first post.
Cassio
Senior
Postby mderksen » 23 Feb 2012, 12:54
Cassio wrote:Read about audio feedback in the first post.
You mean:
Problem: audio feedback (Larsen effect), sound loop between input (microphone) and output (speakers).
Solution: mute iGain and increase iMix or Mic if microphone doesn't work
It's a very loud sound so could it be the larsen effect? If yes, edit this in Info.plist right? I have to reinstall Lion or can i boot without starting the VoodooHDA.kext?
mderksen
Postby Cassio » 23 Feb 2012, 15:07
Yes, that's it (I guess).
Boot in single user mode, remove kext, then install the edited kext.
Boot with -s
Code: Select all
mount -uw /
rm -r /System/Library/Extensions/VoodooHDA.kext
reboot
You can also play with iGain/iMix values in the prefPane.
Cassio
Senior
Postby mderksen » 24 Feb 2012, 08:28
Thank you! It fixed the sound. :mrgreen:
mderksen
Postby lasVegasMac » 29 Feb 2012, 00:58
i tryed to edit my info plist and it says that it cant be saved
what can i do
thanks
all working bot audio not completely ok
laptop compal hel 80 c * nvidia ge force go 7600 * audio alc 883 not completly ok * intel core 2 duo t 5600 1.8
with all problems but runnin good THANKS TO ALL COMUNITY
lasVegasMac
Postby Cassio » 29 Feb 2012, 01:09
Run editor with sudo or copy kext to desktop, edit and install it again.
Remember to repair permissions and update cache (or use a tool like Kext Wizard to install).
Cassio
Senior
PreviousNext
Return to Guides and tutorials
Users browsing this forum: No registered users and 7 guests
