olarila.com
Mac OS X x86 - Hackintosh
It is currently 21 May 2013, 12:02
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3, 4  Next
Author Message
PostPosted: 19 Feb 2012, 20:50
iGenius
You need NullCPUPM while you don't patch AICPUPM, read topic about DSDT patching, there's a link to SpeedStepper.
For video you probably need DualLink patch in DSDT.
For wireless you need proper kexts or DSDT patch if it's AR9285.
Audio viewtopic.php?f=18&t=454
_________________
Top
 Profile
PostPosted: 20 Feb 2012, 11:19
GeekInTraining
I found the kexts for the audio and wireless and video (intel hd 3000). Before installing the audio kext i have to remove AppleHDA.kext right?
What would you advise to do in what order after instaling Lion?
1: Patch dsdt.aml file (which patched do i need more, do i need every sandybridge patch?)
2: Copy /Extra folder for MacBookPro 8.1
3: Install Chameleon bootloader and copy patched dsdt.aml file
4: Install kexts and repair permissions
5: Install NullCPUPM/speedstepper and fakesmc
Is this the right order or do i miss something? I downloaded the speedstepper file. Do i have to patch this for my dsdt.aml file?
Sorry for the noob questions but the tutorial does not give me this information :oops: When i get it working i can help others with the N53SV and maybe write a tutorial :) And i still want to buy you a beer ;)
Top
 Profile
PostPosted: 20 Feb 2012, 15:13
iGenius
Don't apply all patches, just the ones you need.
SpeedStepper is a program that patches AICPUPM.
Read viewtopic.php?f=19&t=634
_________________
Top
 Profile
PostPosted: 21 Feb 2012, 15:34
GeekInTraining
Do you think i need more patches then DTGP, EHCI, FN KEYS, IRQS? I don't know what the others fix :oops: I think i do know what shutdown fixes but not what the others do ;)
HDEF _DSM, HPET, LPC, PARSEOP_IF, PNLF SB, RTC, SHUTDOWN, SMBUS, UHCI, _T_x rename
I can boot Lion now without kernel panic. (reinstalled Lion 8 times now) I used NullCPUPowerManagement.kext but now i see AppleIntelCPUPowerManagement patcher so i'm going to try this one today. If i use the AppleIntelCPUPowerManagement patcher, should i run the speedstepper script too?
Also the audio, video and wireless is not working. For audio i'm going to follow your topic. For wireless is a patch like you said so i'm going to have to try that one too. Chameleon also has an update to 4.0.0 so i'm going to try that one too today
Top
 Profile
PostPosted: 21 Feb 2012, 16:30
iGenius
You have to test to know if you need other patches or not, for example, if AppleLPC is loaded without LPC patch, you don't need it, if you don't have KP "no HPETs available" you don't need HPET patch. Read the topic.
AICPMPatcher does the same as SpeedStepper, the difference is it's "generic" (should work for any version of the kext) while SpeedStepper has a specific version for each kext.
For wireless you have to look in ioreg for the correct place to insert it viewtopic.php?f=7&t=93
_________________
Top
 Profile
PostPosted: 27 Feb 2012, 21:00
GeekInTraining
I got the sound working but the Wifi and HD3000 are not working. Trying to get these working for days now.
What works:
+ sound
+ keyboard/touchpad
+ usb2.0 and usb3.0
+ reboot and shutdown
What doesn't work:
- Wifi
- HD3000 / video
- FN-keys and other sound-related keys (mute, volume up/down etc.)
For video is see during boot:
ERROR: dcbtable_version is 0x4
ERROR: nVidia ROM Patching Failed!
Max resolution is 1024x768. I can edit org.chameleon.Boot.plist for Graphics Mode 1920x1080 but when i do that i think i get a kernel panic. I really dont want to try that again ;-)
For Wifi: i tried the patch for the kext. I see the icon on top and it tries to connect but it keeps failing,
I even try to patch my clean DSDT with the N73SV patch. Some people say they fixed their HD3000 with this.
Any ideas what i can do?
Top
 Profile
PostPosted: 27 Feb 2012, 21:29
iGenius
Try the patch DualLink for HD3000.
Attach your patched DSDT and ioreg dump, I will check if AR9285 patch is correct.
_________________
Top
 Profile
PostPosted: 27 Feb 2012, 21:48
GeekInTraining
Hmm found a duallink patch in the DSDT section but if i try to patch my DSDT i get:
21:45:56: Errors persisted all fixing tentatives, please post this log at olarila.com forums
[[Line 8507 type Error message Name already exists in scope (_DSM)]]
21:45:56: Aborted, compilation failed
See attachment for DSDT, ioreg and screenshot of systeminfo.
Top
 Profile
PostPosted: 28 Feb 2012, 04:03
iGenius
Try this
dsdt.aml.zip
If it doesn't work try this kext
http://www.osx86.net/view/1279-atheros_ar9285_fix.html
_________________
Top
 Profile
PostPosted: 28 Feb 2012, 19:23
GeekInTraining
Cassio wrote:
Try this
dsdt.aml.zip
Used the kext from the link and your DSDT but still can't connect to my wifi :( . It tries to connect but shows this sign !
Example of the ! http://www.askdavetaylor.com/3-blog-pic ... r-icon.png
Top
 Profile
Search for:
Jump to:
