I patched my original dsdt.aml file first with DTGP. No errors.
After that i patched it with EHCI. No errors.
After that i patched it with IRQs. No errors.
I tried to boot the USB disk and it loads more than before. Only now i get the error:
Code:
acpi_smc_platformplugin:: start waitforservice resourcematching appleintelcpupowermanagement timed out
I also added a screenshot with a few errors.
When i Google this people says to use some flags. So i used the flags -v -x cpus=1 GraphicsEnabler=No
These flags didn't help. Could it be it has something to do with kext?
I found some boot files for N53SV here:
http://www.osx86.net/downloads.php?do=file&id=2277This contains a folder called Extensions in /Extra with a couple of kext. Maybe i could use them.
Or maybe i could do the following. Don't install "Extra Lion" but just copy this Extra folder with my own patched dsdt.aml file and then install Chameleon.
*edit*
I tried removing the Extra folder and copied the Extra folder from the link above. I replaced the dsdt.aml file with my own patched one. I installed Chameleon and booted the disk.
First time booting it loaded and gave me this image:
http://i63.photobucket.com/albums/h123/sk8erdesign/erro-1.jpg.
I rebooted and started the USB disk again and i got a kernel panic.
