olarila.com
Mac OS X x86 - Hackintosh
It is currently 19 Jun 2013, 05:27
Post new topic Reply to topic  [ 11 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: 06 Dec 2011, 02:21
eGeek
I've installed Lion 10.7.1 on RIIIE.
Works:
Sound - AppleHDA (ALC889) binary patched
Videos - (2 Asus GTX 470 in SLI) EFI inject. SLI is supported by Lion??
Network OK, only if... after waking up the LED on the router's LAN network from green to yellow, 1GB to 100MB, the only way to restore it is to reboot.
DVDR: PlextorPX880SA, Works but sometimes, (only without inserted DVD/CD) seems to turn on the burner and makes "funny noises ..." but it works. Maybe not 100% compatible ...?
Unresolved issues:
My ICH10 is seen as ICH8, The two pairs of disks in raid0 are seen as external. How to fix?
Sleep, do not go to sleep, or better, after a couple of seconds wakes up alone.
I run: grep Wake / var / log / kernel.log
Code:
Mac-Pro-to-Luke: Luke ~ $ grep Wake / var / log / kernel.log
Dec 5 02:53:51 Mac-Pro-of-Luke kernel [0]: Wake reason: EHC2
Dec 5 03:19:32 Mac-Pro-of-Luke kernel [0]: Wake reason: EHC2
Dec 5 03:20:55 Mac-Pro-of-Luke kernel [0]: Wake reason: EHC2
Then I followed this guide: http://www.insanelymac.com/forum/index. ... &p=1533492
My unmodified EHC2 in DSDT:
Code:
Device (EHC2)
                Name (_ADR, 0x001A0007)
                    Store (Package (0x07)
                            "AAPL,current-available",
                            0x05DC,
                            "AAPL,current-extra",
                            0x04B0,
                            "AAPL,current-in-sleep",
                            0x09C4,
                            Buffer (One)
                                0x00
                        }, Local0)
                    Return (Local0)
                Method (_PRW, 0, NotSerialized)
                    Return (GPRW (0x0D, 0x04))
I deleted the PSW method, but nothing. Try this? :
viewtopic.php?p=3521#p3521
_________________
Asus RIIIE - i7 950 - Ram: 12GB - Video: 2x GTX 470 1GB - ML 10.8
Acer 6930G - Ram: 4GB - Video: 9600GT 1GB - Lion 10.7.3
Top
 Profile
PostPosted: 08 Dec 2011, 04:09
iGenius
viewtopic.php?f=19&t=634
Quote:
If the system goes to sleep and wakes immediately, look for "Wake reason" in kernel log and edit method _PSW or remove _PRW from that device in DSDT.
_________________
Top
 Profile
PostPosted: 06 Mar 2012, 21:48
eGeek
I take this discussion after several months because I could not fix the sleep. I updated to 10.7.3 and I can no longer issue the command: grep Wake / var / log / kernel.log.
The problem of lan as explained in my first post, continues to be ...
Ideas, Hint ...
_________________
Top
 Profile
PostPosted: 06 Mar 2012, 21:50
iGenius
Command must be
Code:
grep Wake /var/log/kernel.log
without all those spaces.
_________________
Top
 Profile
PostPosted: 06 Mar 2012, 23:46
eGeek
@Cassio, After command:
Code:
Last login: Tue Mar  6 23:32:09 on console
Mac-Pro-di-L:~ l$ grep Wake /var/log/kernel.log
Binary file /var/log/kernel.log matches
Mac-Pro-di-L:~ l$
???Hint???
_________________
Top
 Profile
PostPosted: 07 Mar 2012, 00:48
iGenius
Open file with text editor and search for Wake.
Anyway, I guess it will be still the EHC2 which is causing the wake, so remove _PRW from it.
_________________
Top
 Profile
PostPosted: 07 Mar 2012, 19:11
eGeek
Ok Cassio Thx, I Solved removing _PRW method.
...the problem now are two:
LAN, this is the message of console after wake:
Code:
kernel: Intel82566MM info: Link is Up 100 Mbps Full Duplex, Flow Control: None
from 100Mbps to 1000Mbps
Auto Sleep not go...
_________________
Top
 Profile
PostPosted: 07 Mar 2012, 19:46
eGeek
For Auto sleep i solved with a your old post:
viewtopic.php?p=6364#p6364
_________________
Top
 Profile
PostPosted: 07 Mar 2012, 20:23
iGenius
Try AppleIntelE1000e
http://sourceforge.net/projects/osx86drivers/
_________________
Top
 Profile
PostPosted: 07 Mar 2012, 21:30
eGeek
I deleted: Intel82566MM.kext from IONetworkingFamily.kext/Contents/Plugins
I installed: AppleIntelE1000e.kext, Lion boot ok and lan is ok but now won't sleep... :cry:
system wake immediatly but the screen remains black...
this version of AppleIntelE1000e.kext are: 1.9.5, try an old version... or is a DSDT problem...?
_________________
Top
 Profile
Search for:
Jump to:
