olarila.com
Mac OS X x86 - Hackintosh
It is currently 25 May 2013, 10:14
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Author Message
 Post subject: Re: AppleHDA in Lion
PostPosted: 04 Oct 2011, 00:07
Noob
plz i need ALC270
in my laptop Hp
Lion And Snow Leopard
Top
 Profile
PostPosted: 15 Oct 2011, 01:24
Noob
I own a Gigabye GA-965P-S3. I tried the method described here to pack a 10.7.2 AppleHDA. Nothing worked. I have an AppleHDA that used to work in 10.7.1 and an old SL one, that Mald0n kindly posted on the InsanelyMac forums. I tried to take the data from either one of them to build a successful 10.7.2 AppleHDA, but all failed. Need advice: here is what i have so far:
http://www.mediafire.com/?97jkk9fxpbs4284
The 10.7.2 v is the one i tried to build.
PS: the old SL version somehow works in 10.7.2, but has severe mic issues.
PPS: oh, and i use a dsdt generated with dsdt autopatcher.
Top
 Profile
PostPosted: 16 Oct 2011, 00:17
Staff
the applehda from 10.7.1 works in 10.7.2 just reinstall the kext.
because 10.7.2 update change the applehda in 10.7.1
_________________
PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI - ML 10.8.3/ Lion 10.7.5/SL 10.6.8/W 8 Pro x64/Ubuntu 12.04 - Quadriboot GUID - My OS X Files - join me at irc.freenode.net/#olarila
Top
 Profile
PostPosted: 16 Oct 2011, 00:39
Noob
It doesn't work for me :(
Although it used to work, it doesn't seem to be a Lion AppleHDA. It has no layouts or Platforms.xml. Its version 2.0.8 and the info.plist shows build 11A421. I've attached it to have a thoroughly look at it.
http://www.mediafire.com/?8hjk8jwui0y72dz
Top
 Profile
PostPosted: 16 Oct 2011, 19:25
GeekInTraining
This HDA is not from Lion.
See first post from MaLd0n how it works. Get your layout.xml, platforms.xml and info.plist from your working system (SL).
You can use HDA Wizard: http://www.insanelymac.com/forum/index. ... 66531&st=0
Here's one for your ALC883
http://www.insanelymac.com/forum/index. ... 531&st=20# (post #24)
Maybe you can get it to work for yourself :)
But you have first to remove all the old stuff like HDAenabler, ALC8xxHDA ….etc
And replace the original AppleHDA from 10.7.2
Good luck :)
Use Realtek ALC883 for the bin patch
[Edit]
Here's one from oldnapalm for LionGM, you can try also, or use the layout.xml, platforms.xml and info.plist:
http://www.mediafire.com/file/252yozzp7 ... LionGM.zip
_________________
GA-P35C-DS3R | Intel Pentium E6500 | 8GB DDR3 | Gigabyte HD 5670 | WD 640GB | 10.7.1
GA-EX58-UD5 i7-920 | 12Gb | Gigabyte HD 6850 | OCZ VERTEX2, 60GB SSD | 10.7.2
GA-Z68X-UD3H-B3 | i7-2600K@3.4GHz | 8GB | POV 8800GT 512MB | WD 2TB SATA3 | 10.7.2
Top
 Profile
PostPosted: 16 Oct 2011, 22:32
Noob
I think i tried those xmls and they didn't work. You happen to know of a good howto or tutorial on how to get this data for a certain mobo? Apparently i need to build the 3 files for myself :(
EDIT: I've tried everything, every combination and every set of xmls available on the internet for the 883. None work, except for the old SL version i posted in the first mediafire link. I guess I only have 2 options, try to bake my own xmls (which i have no idea how to do) or buy a soundcard that is natively supported in Lion (again none that i know of). Any help on any of the 2 topics is welcome :)
Top
 Profile
PostPosted: 20 Oct 2011, 04:35
iGenius
Do as explained in the first post, but:
- CommonPeripheralDSP, PathMaps, LayoutID and PathMapRef you will get from AppleHDA.kext (old SL version).kext/Contents/PlugIns/AppleHDAPlatformDriver.kext/Contents/Info.plist
- dict from key HDAConfigDefault you will get from AppleHDA.kext (old SL version).kext/Contents/PlugIns/AppleHDAHardwareConfigDriver.kext/Contents/Info.plist
_________________
Top
 Profile
PostPosted: 02 Nov 2011, 08:30
GeekInTraining
MaLd0n wrote:
iLegendary wrote:
i cant get audio with ad1988bfix and dsdt.. ??
in Lion or 10.6.8
you dont need legacy
use HDEF in DSDT + AppleHDA patched
hi, on my p5e3 deluxe i tied ti use HDEF and AppleHDA patched for my ad1988 (in the bios is selected hda audio), but
my audio card doesn.t work( no audio detected).
what should i do???( whit voodoohda 2.7.2 works).
thanks
_________________
Lion 10.7.5, q6600 - p5e3 deluxe GTX 550 ti 1 gb - 8 gb ddr3 corsair 1600
Top
 Profile
 Post subject: Help me please...
PostPosted: 03 Nov 2011, 20:21
Noob
Hello, my system is Lion 10.7.2... (32 BITS) with Realtek ALC888
I patched the AppleHDA with binary code, changed the "Pin Config" with the my:
"01171CF0 01171D11 01171E11 01171F41 01271CF0 01271D11 01271E11 01271F41 01471C10 01471D44 01471E01 01471F01 01571C20 01571D01 01571E13 01571F99 01671CF0 01671D11 01671E11 01671F41 01771CF0 01771D11 01771E11 01771F41 01871C50 01871D9C 01871EA1 01871F01 01971C60 01971D9D 01971EA1 01971F02 01A71C5F 01A71D34 01A71E81 01A71F01 01B71C30 01B71D45 01B71E21 01B71F02 01C71CF0 01C71D11 01C71E11 01C71F41 01D71C29 01D71DC6 01D71E16 01D71F40 01E71C40 01E71D71 01E71E44 01E71F01 01F71CF0 01F71D11 01F71E11 01F71F41"
(from Windows 7 32 BITS, it's fixed already), changed de "CODECID" in Info.plist from AppleHadware... to
my code: "283,904,133" and add patch DSDT, too, for ALC888:
Code:
Device (HDEF)
                Name (_ADR, 0x001B0000)
                    Store (Package (0x08)
                            "codec-id",
                            Buffer (0x04)
                                0x88, 0x08, 0xEC, 0x10
                            "layout-id",
                            Buffer (0x04)
                                0x78, 0x03, 0x00, 0x00
                            "device-type",
                            Buffer (0x0F)
                                "Realtek ALC888"
                            "PinConfigurations",
                            Buffer (One)
                                0x00
                        }, Local0)
                    Return (Local0)
installed the kext patched in reboot, but Not Worked it...
I need create the "plataform.xml" and "layout888.xml" fixed for my soundcard? if is true, how to make or fix them, for my sound card?
PLEASE, HELP ME...
PD: When reboot my system, in system profile the sound card is recognized with all IN/OUTPUS, but in system preferences not appears nothing...
Top
 Profile
PostPosted: 09 Nov 2011, 03:17
GeekInTraining
I have this board, rev. 3.3, and after doing all the codec dumps I realized that the board actually uses ALC888, not ALC883. Have you tried bin patching for this chipset? You may have better results (with the modified DSDT).
Here is my DSDT if you care to try.
_________________
OSX Lion 10.7.2 (Apple Update to 10.7.4)
Gigabyte GA-965P-S3 - rev3.3 - F14 BIOS (Chameleon v2.1 r2035)
Asus GeForce 8400GS 1Gb DDR3
E6420 Duo Core 2 | 4Gb RAM
23" Apple Cinema Display | BT Apple Magic Mouse | HP GX607AA Webcam
Top
 Profile
Search for:
Jump to:
