olarila.com
Mac OS X x86 - Hackintosh
It is currently 22 May 2013, 10:49
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Author Message
 Post subject: Re: AppleHDA in Lion
PostPosted: 28 Jul 2011, 13:06
Noob
okay nvm it works. i just didn't patch hdef.. seeing as the auto patcher didn't do it for me, haha.
thanks a lot anyways! audio working as planned. :)
Top
 Profile
PostPosted: 01 Aug 2011, 09:12
GeekInTraining
this mode is for enable AppleHDA for alc88x without problem, and avoid the kernel panic on reboot ?
Top
 Profile
PostPosted: 27 Aug 2011, 19:29
Noob
Ayuda por favor, con ALC888 y Mac OS X Lion, cual es el "PIN Configuration" para que trabajen los puertos frontales,
por favor los necesito, muchas gracias
Top
 Profile
PostPosted: 05 Sep 2011, 08:16
Noob
hi all i have an old alcinject.kext with patched applehda.kext which works fine fro me in snowleo but it dosent work for me in lion . I have attached both the kexts can anbody guide me how to patch apple hda from lion to get my audio working
my audio driver is realtek alc 880.
Top
 Profile
PostPosted: 05 Sep 2011, 16:05
Staff
Follow instructions in first post (use PlistEdit Pro), but instead of taking values from "legacy" you will take them from AppleHDA plug-ins.
CommonPeripheralDSP, PathMaps, LayoutID and PathMapRef come from AppleHDA.kext/Contents/PlugIns/AppleHDAPlatformDriver.kext/Contents/Info.plist
The dict from HDAConfigDefault comes from AppleHDA.kext/Contents/PlugIns/AppleHDAController.kext/Contents/Info.plist
Copy data from ALCinject.kext (entriesToAdd) to HDEF in DSDT
Code:
                    Store (Package (0x06)
                            "built-in",
                            Buffer (One)
                                0x00
                            "layout-id",
                            Buffer (0x04)
                                0x0C, 0x00, 0x00, 0x00
                            "PinConfigurations",
                            Buffer (Zero) {}
                        }, Local0)
                    Return (Local0)
Top
 Profile
PostPosted: 06 Sep 2011, 09:45
Noob
AppleHDA.kext/Contents/Resources/Platforms.xml
My resources Folder Does no have platforms.xml
Top
 Profile
PostPosted: 06 Sep 2011, 18:32
Staff
Then it's not a Lion AppleHDA.
Top
 Profile
PostPosted: 06 Sep 2011, 18:43
GeekInTraining
Old...
Do you know if it works with ALC888b ? I'm trying for days... I have used several alc888b kexts as base to edit the values on AppleHDA in Lion... but no lucky...
I don't want to keep trying if it's impossible, so I'm asking you if you know some "success case" with this ALC888b...
Top
 Profile
PostPosted: 06 Sep 2011, 18:54
Staff
I don't remember about a "success case" with this specific codec, but if the kext works in Snow Leopard, the Lion "port" should work as well.
Top
 Profile
PostPosted: 06 Sep 2011, 19:06
GeekInTraining
I'm using the values from LegacyHDA_ALC888B.kext... this kext used to work on Snow Leopard in Extra/Extensions... with AppleHDA.kext from 10.6.2 in S/L/E... my DSDT has HDEF...
Am I doing something wrong?
Top
 Profile
Search for:
Jump to:
