olarila.com
Mac OS X x86 - Hackintosh
It is currently 23 May 2013, 18:42
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
Author Message
PostPosted: 08 Sep 2011, 01:50
eGeek
Now, when i boot, it's possible only in verbose mode, the procedure stops to:
FakeSMCDevice: 17 preconfigured keys added
FakeSMCDevice: succesfully initialized
Do you think, is necessary to do a clean installation with a 10.6.8 Combo re-update, following a right procedure?
_________________
Asus RIIIE - i7 950 - Ram: 12GB - Video: 2x GTX 470 1GB - ML 10.8
Acer 6930G - Ram: 4GB - Video: 9600GT 1GB - Lion 10.7.3
Top
 Profile
PostPosted: 08 Sep 2011, 02:08
Staff
No idea, I never saw such a thing.
Did you try booting after update without replacing IOPCIFamily and AppleACPIPlatform? If it hangs at "PCI configuration begin" you can try "npci=0x2000" as boot flag.
http://www.insanelymac.com/forum/index. ... try1706503
Do you have SMboardproduct in SMBIOS?
Top
 Profile
PostPosted: 11 Sep 2011, 08:00
eGeek
Yes, my SMboardproduct is: Mac Pro 3.1
_________________
Top
 Profile
PostPosted: 11 Sep 2011, 15:16
Staff
SMboardproduct should be something like Mac-F42C88C8.
It may not be the cause of your problem, but on a laptop you should use a MacBookPro SMBIOS.
Top
 Profile
PostPosted: 14 Sep 2011, 23:46
eGeek
I updated to 10.6.8 from 10.6.3 (Retail DVD version). I used your advice oldnapalm. Thanks again! The only problems I have now, are: USB Card Reader Integrated, which worked well in 10.6.7, using the package Apple Storage DriversV2 from:
http://www.kexts.com/downloads.php?do=file&id=618
I tried replacing AppleStorageDrivers.kext and AppleSDXC.kext with versions of 10.6.7, but nothing. For Audio, if I use the AppleHDA.kext patched with Enabler + Legacy versions of 10.6.7 no sounds... Voodoo? Some help-advice?
Thanks ...
_________________
Top
 Profile
PostPosted: 15 Sep 2011, 04:02
Staff
Try VoodooHDA for audio
viewtopic.php?f=18&t=454
For USB card reader you can try this
http://www.insanelymac.com/forum/index. ... pic=237068
Top
 Profile
PostPosted: 15 Sep 2011, 23:16
eGeek
Unfortunately, I edited the info. plist with the information of my usb-card reader (USB2.0-CRW) but nothing ...
_________________
Top
 Profile
PostPosted: 16 Sep 2011, 00:00
Staff
Do NOT edit idProduct and idVendor that are under IOProviderMergeProperties, those are the injected values.
Top
 Profile
PostPosted: 16 Sep 2011, 20:27
eGeek
Thanks, I edited the info.plist as you suggest me. And now it works.
For suond, I tried again to make a list of verbs functioning, I had already followed the tutorial from The King sometimes, trying to patch the AppleHDA, but nothing. Now I followed your tutorial and I can have a working kext to 90 percent, because as usual the fuc... internal mic, does't want to work (I have an HDMI output on the left side of the notebook). I read somewhere that may be in conflict ...
My verbs list:
Code:
01271c20 01271d01 01271eA3 01271f59
01471c10 01471d01 01471e13 01471f90
01571c40 01571d10 01571e21 01571f03
01671c80 01671d11 01671e11 01671f01
01771c90 01771c11 01771e11 01771f01
01871c30 01871d90 01871ea1 01871f03
01971cA0 01971d11 01971d11 01971f01
01A71c60 01A71d30 01A71e81 01A71f01
01B71cB0 01B71d11 01B71d11 01B71f01
01C71cC0 01C71d11 01C71e11 01C71f01
01D71c50 01D71d80 01D71e16 01D71f40
01E71c70 01E71d10 01E71e45 01E71f00
01F71cD0 01F71d11 01E71e11 01E71f01
_________________
Top
 Profile
PostPosted: 16 Sep 2011, 20:41
Staff
Are you using AppleHDA or VoodooHDA?
If it's VoodooHDA try to create one entry for each card in IOKitPersonalities to avoid conflict
viewtopic.php?f=18&t=454#p4436
About verbs, which node is the internal mic?
Top
 Profile
Search for:
Jump to:
