Mac OS X 10.6.3 Snow Leopard bootable USB for Intel PCs
Re: Mac OS X 10.6.3 Snow Leopard bootable USB for Intel PCs
Postby righN » 14 Nov 2016, 18:48
pernacabeluda wrote:Make sure you have device HPET in DSDT and IRQs patch is applied. Put compiled DSDT.aml in /Extra.
X3100 kexts are 32 bit only so you have to add arch=i386 to kernel flags. If your device ID is 2a12 you need to patch kexts
viewtopic.php?f=3&t=144
I added arch=i386 to the kernel flags, patched kexts because yes my device ID is 2a12. But that didin't help, maybe I used wrong kexts?
And how to add device HPET to the DSDT?
righN
CPU: Intel Celeron CPU 550
Motherboard: HP laptop
GPU: Intel X3100
Postby pernacabeluda » 14 Nov 2016, 20:58
You should use original kexts, just run the commands to patch them and update caches
Code: Select all
sudo perl -pi -e 's|\x86\x80\x02\x2a|\x86\x80\x12\x2a|g' /System/Library/Extensions/AppleIntelGMAX3100FB.kext/AppleIntelGMAX3100FB
sudo perl -pi -e 's|0x2A028086|0x2A128086|g' /System/Library/Extensions/AppleIntelGMAX3100FB.kext/Info.plist
sudo perl -pi -e 's|\x86\x80\x02\x2a|\x86\x80\x12\x2a|g' /System/Library/Extensions/AppleIntelGMAX3100.kext/Contents/MacOS/AppleIntelGMAX3100
sudo perl -pi -e 's|0x2a028086|0x2a128086|g' /System/Library/Extensions/AppleIntelGMAX3100.kext/Contents/Info.plist
If there's no HPET in your DSDT, use this patch
http://olarila.com/Patches/Misc/New%20HPET.txt
pernacabeluda
Senior
Postby righN » 20 Nov 2016, 11:26
pernacabeluda wrote:You should use original kexts, just run the commands to patch them and update caches
Code: Select all
I did that but it didin't help :(
righN
GPU: Intel X3100
Previous
Return to Snow Leopard (10.6)
