Mac OS X 10.6.3 Snow Leopard bootable USB for Intel PCs
Re: Mac OS X 10.6.3 Snow Leopard bootable USB for Intel PCs
Postby righN » 06 Nov 2016, 09:58
pernacabeluda wrote:Try to copy boot file and Extra folder from USB to HD.
I only copied Extra folder because I couldn't find a boot file. But that didin't help, I used boot file from r2069 version and now everytime when I'm trying to boot it shows Can't find /mach_kernel.
righN
CPU: Intel Celeron CPU 550
Motherboard: HP laptop
GPU: Intel X3100
Postby pernacabeluda » 06 Nov 2016, 19:49
mach_kernel should be there, it's installed by default, I have no idea why it's not, you can copy from the installer.
Both mach_kernel and boot files are hidden
viewtopic.php?f=2&t=2919
pernacabeluda
Senior
Postby righN » 07 Nov 2016, 17:14
pernacabeluda wrote:mach_kernel should be there, it's installed by default, I have no idea why it's not, you can copy from the installer.
Yep, mach_kernel was there. I tried to use boot file from USB but it gave me this
boot0: test
boot0: test
boot0: done
boot1: error
When I tried to use mach_kernel from the USB with boot file from r2069 version it gave me the same error Can't find /mach_kernel
righN
GPU: Intel X3100
Postby pernacabeluda » 07 Nov 2016, 20:51
If you are using the installer from this topic, boot file is Clover, copy boot1 from USB and rename it to boot.
pernacabeluda
Senior
Postby righN » 08 Nov 2016, 14:36
pernacabeluda wrote:If you are using the installer from this topic, boot file is Clover, copy boot1 from USB and rename it to boot.
Yes I'm using installer from the topic, boot file worked but it still shows the same can't find /mach_kernel.
righN
GPU: Intel X3100
Postby righN » 08 Nov 2016, 20:05
pernacabeluda wrote:Try this
viewtopic.php?f=27&t=2899
I'm stuck at apple gray logo again... When booting in verbose mode after loading kexts I get black screen.
righN
GPU: Intel X3100
Postby pernacabeluda » 08 Nov 2016, 20:59
Can you boot the installed system if you start from USB? Did you copy Extra folder from USB to HD?
pernacabeluda
Senior
Postby righN » 11 Nov 2016, 18:32
pernacabeluda wrote:Can you boot the installed system if you start from USB? Did you copy Extra folder from USB to HD?
Uh, I forgot that I deleted it. Okay computers boots without problems now but now with those IRQs, I patched them, restored AppleHPET.kext but my mouse didin't work after restart. And another problem is with graphics, kext is installed but I can only use 1024x768 resolution and programs like Google Chrome are laggy.
righN
GPU: Intel X3100
Postby pernacabeluda » 14 Nov 2016, 12:12
Make sure you have device HPET in DSDT and IRQs patch is applied. Put compiled DSDT.aml in /Extra.
X3100 kexts are 32 bit only so you have to add arch=i386 to kernel flags. If your device ID is 2a12 you need to patch kexts
viewtopic.php?f=3&t=144
pernacabeluda
Senior
PreviousNext
Return to Snow Leopard (10.6)
