Mac OS X 10.6.3 Snow Leopard bootable USB for Intel PCs
Re: Mac OS X 10.6.3 Snow Leopard bootable USB for Intel PCs
Postby sanshiro21 » 12 Jan 2016, 01:19
I cant find the link, can anyone help me please
sanshiro21
CPU: x64
Motherboard: xx
GPU: 586
Postby mendietinha » 12 Jan 2016, 07:36
Access chat to get download link (channel topic).
first thing you will see is a welcome and a pastebin link.
mendietinha
Staff
CPU: i5 750
Motherboard: Intel
GPU: GTX760
Postby righN » 03 Nov 2016, 20:26
Hi, I'm trying to install Snow Leopard on my HP Compaq 6720s. I made bootable USB, but I have problems when I'm trying to install Mac OS X.
With Clover (tried bootflags like GraphicsEnabler=No, USBBusFix=Yes, -f, -x didin't help) :
With Chameleon (tried bootflags like USBBusFix=Yes, USBLegacyOff=Yes, -x didin't help):
righN
CPU: Intel Celeron CPU 550
Motherboard: HP laptop
GPU: Intel X3100
Postby pernacabeluda » 03 Nov 2016, 21:58
Try to move AppleHPET.kext from /System/Library/Extensions and boot with -f
If it works, patch IRQs in device HPET in DSDT and restore the kext
http://olarila.com/Patches/Misc/IRQs.txt
pernacabeluda
Senior
Postby righN » 04 Nov 2016, 13:38
pernacabeluda wrote:Try to move AppleHPET.kext from /System/Library/Extensions and boot with -f
Okay, I installed Mac OS X when deleted AppleHPET.kext but I didin't patched IRQ because I didin't know how and now my USB mouse isn't working and I don't have internet on my computer :/
righN
GPU: Intel X3100
Postby pernacabeluda » 04 Nov 2016, 14:07
Boot with the installer, open terminal (utilities menu) and rename AppleHPET from installed partition
Code: Select all
cd /Volumes/"your partition name"/System/Library/Extensions
mv AppleHPET.kext AppleHPET.kext.orig
Boot with -f and you should have working mouse.
How to patch IRQs
viewtopic.php?f=19&t=634
For networking you need to install proper kext
viewtopic.php?f=28&t=1694
pernacabeluda
Senior
Postby righN » 04 Nov 2016, 22:31
pernacabeluda wrote:Boot with the installer, open terminal (utilities menu) and rename AppleHPET from installed partition
Code: Select all
How to patch IRQs
Ok I managed to get my mouse and internet working but I can't manage bootloader to work. I installed it with Chameleon Wizard and when I'm trying to boot I get apple gray logo freeze when I tried to boot with -v -f I saw loading up kexts and then a black screen...
righN
GPU: Intel X3100
Postby pernacabeluda » 05 Nov 2016, 02:34
Try to use same Chameleon version as in USB installer.
pernacabeluda
Senior
Postby righN » 05 Nov 2016, 09:37
pernacabeluda wrote:Try to use same Chameleon version as in USB installer.
I installed 2.1 r2069 not 2.1 r2109 which is on the USB because I couldn't find a working installer but that didin't fix the problem anyway. But in the start when I tried to boot it showed me that it can't find /mach_kernel but after some tries to boot it worked but I got black screen anyways.
righN
GPU: Intel X3100
Postby pernacabeluda » 06 Nov 2016, 02:54
Try to copy boot file and Extra folder from USB to HD.
pernacabeluda
Senior
PreviousNext
Return to Snow Leopard (10.6)
