olarila.com
Mac OS X x86 - Hackintosh
It is currently 20 Jun 2013, 11:51
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: 17 Jul 2011, 20:26
GeekInTraining
Hi i have try to install hazard 10.6.6 on my p35 neo 2 platinum, but installation on drive utility don't recognize any drive sata recognize only cd drive and usb flashpen
this is my machine
intel quad core q9300- MSI p35 platinum (ms-7345) - MSI gtx 560 ti frozer II/OC- 4 GB RAM KINGSTON DDR2 800 HYPERX - ethernet Realtek RTL8168B/8111B - audio Realtek ALC888 - SAMSUNG HD753LJ sata 750gb - seagate barracuda sata 500GB - dvd/rw pionner 111D - win xp pro sp3 - win 7 64 - OCZ MODXSTREAM PRO 600W
i've try another method viewtopic.php?f=16&t=136
after booth cd press f5 insert retail dvd leopard but don't recognize try with hackboot v6 and osx86 mod cd 0.31
ahci not support by my modo in sata drive only on raid (not used by me) video used by me is msi gtx 560 other video is old video driver
report Tsuru.rar
please help me !! problem is dsdt table ?
Top
 Profile
PostPosted: 20 Jul 2011, 13:36
GeekInTraining
Are you using the ICH9 ports? That is SATA3~SATA6
Don't use the Marvell port (SATA7).
In BIOS don't use RAID.
You do have AHCI. Look for it. It's the next option after RAID mode.
AHCI Devices Group
Press <Enter> to enter the AHCI settings sub-menu. The submenu displays the status of auto detection of IDE devices.
AHCI Port0~5
Press <Enter> to enter the sub-menu. These submenu allow users to select the type of devices connected to the system.
Download/Read the manual: http://us.msi.com/service/download/manual-5519.html
_________________
GA-P35C-DS3R | Intel Pentium E6500 | 8GB DDR3 | Gigabyte HD 5670 | WD 640GB | 10.7.1
GA-EX58-UD5 i7-920 | 12Gb | Gigabyte HD 6850 | OCZ VERTEX2, 60GB SSD | 10.7.2
GA-Z68X-UD3H-B3 | i7-2600K@3.4GHz | 8GB | POV 8800GT 512MB | WD 2TB SATA3 | 10.7.2
Top
 Profile
PostPosted: 21 Jul 2011, 14:17
GeekInTraining
yes ok ..... my problem is able AHCI on sata disk in bios don't present this option show my jpg file
my hd is
samsung HD 753LI ATA DEVICE
STR 500320AS ATA DEVICE (SEAGATE)
this HD have necessary set the jumper to AHCI ?
Top
 Profile
PostPosted: 21 Jul 2011, 22:06
GeekInTraining
all ok i-m activate AHCI in all system ...i-m try reinstall snow 10.6 my hard drive correct recognize i-m select drive select partiton start format .....ERROR FORMATTING AND LOST ALL PARTITION AND DATA OF DISK !!!!!!!!!!!
im try to recover with systemdisk
is becoming a nightmare !!!!!
Top
 Profile
PostPosted: 21 Jul 2011, 22:12
Staff
before any installation
Always make back up
_________________
Top
 Profile
PostPosted: 26 Jul 2011, 18:21
GeekInTraining
hi... i don't have disk for backup 470 GB data ..... have recovery all file thanks to linux systemdisk (beautifuuuuuuuuuuuuuuuuullll utility)
i have installed snow and update to 10.6.8 .... but my video card msi 560 gtx ti don't supported ... in the next day try to install lion ..... nightmare come back :)
Top
 Profile
Search for:
Jump to:
