olarila.com
Mac OS X x86 - Hackintosh
It is currently 19 Jun 2013, 22:58
Post new topic Reply to topic  [ 160 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 16  Next
Author Message
PostPosted: 26 Jul 2011, 20:12
Staff
ctuprde wrote:
MaLd0n wrote:
Quote:
I get a kernel panic
post a photo
update your AppleNforceAta
old bug
_________________
Top
 Profile
PostPosted: 26 Jul 2011, 23:34
GeekInTraining
[/quote]
old bug[/quote]
Updated applenforce to 1.04 successfully, and installed update, but cant boot to it.
Hangs at this screen at startup.
Top
 Profile
PostPosted: 27 Jul 2011, 00:11
Staff
try with npci=0x2000
_________________
Top
 Profile
PostPosted: 27 Jul 2011, 00:59
GeekInTraining
Ok did that and it booted, but now I've lost gpu support as resolution is not at max.
Top
 Profile
PostPosted: 28 Jul 2011, 20:42
GeekInTraining
Still cant get full res to work, and cant boot up unless arch=i386 is used. This all changed after updating to 10.6.8 and changing to appleNforceATA. kext version 1.04
Any ideas?
Top
 Profile
PostPosted: 08 Aug 2011, 03:22
Noob
Hya all,
I followed the instructions, but after the installation, and during the part where you enter your country, keyboard layout and such, my Notebook keeps looping. I get as far as the part where you can use timemachine to copy files from another mac. Of course i don't have one, so i select the lowest option, the one to continue, and click on continue.
IT hangs for a minute or so, with the twirling cursor, so it looks as if he's trying to do something.
From there on it just simply loops back to the welcome screen.
I've reinstalled following your steps once more, but same problem. So it's probably not the installation file.
Am i missing something here?
Mike,
Top
 Profile
PostPosted: 08 Aug 2011, 03:53
Staff
Try booting with -s (single user) and run
Code:
mount -uw /
touch /var/db/.AppleSetupDone
reboot
Top
 Profile
PostPosted: 08 Aug 2011, 10:20
Noob
Next problem.
The command ''touch /var/db/.AppleSetupDone'', does absolutely nothing. =/
Edit, i got it :3
Top
 Profile
PostPosted: 08 Aug 2011, 15:43
Noob
Last problem i hope.
I've fixed a few problems i found, but i'm stuck on two things. For one, the drivers for the Asus U50F. Secondly, i have to have the DVD in the tray to be able to boot Macintosh. Any other way? Without the DVD it'll just go to the chameleon bootmanager, i press enter, and it'll reboot, and the cycle of going to the bootmanager begins again.
Any help would be awsome.
Top
 Profile
PostPosted: 08 Aug 2011, 15:58
Staff
Post the laptop specs
viewtopic.php?f=18&t=63
If the CPU is a Core i you need to update the system to be able to boot from HD with vanilla kernel, it won't work with 10.6-10.6.3.
Top
 Profile
Search for:
Jump to:
