olarila.com
Mac OS X x86 - Hackintosh
It is currently 22 May 2013, 02:58
Post new topic Reply to topic  [ 160 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 16  Next
Author Message
PostPosted: 19 Jun 2011, 11:53
Noob
my pc is
core 2duo 8400
asus p5ql-e
4*2GB ram
ati 5750
samsung 1TB
i've downloaded hackboot cd V5 and boot my pc.
i've done the main settings and as soon as the final installation begins, a window comes and tells me that nessesary files can't be copied to my system....
what should i do???
also, in the first post MALdon gives some extra folders and for me is the imac 9.1. what should i do with it????
thanks
Top
 Profile
PostPosted: 19 Jun 2011, 16:54
Staff
lotos wrote:
Asus p5ql-e
1- Copy the Extra folder to your boot partition
2- Install Chameleon RC5
3- Run DSDT Auto-Patcher and copy the generated DSDT to the Extra folder
4- Update the system to 10.6.7
_________________
Top
 Profile
PostPosted: 20 Jun 2011, 10:06
Noob
the problem is that i can't do the installation.
Top
 Profile
PostPosted: 22 Jun 2011, 10:01
Noob
ok i have managed to install snow leopard.
copy the extra folder
install Chameleon RC5
install DSDT Auto-Patcher for my motherboard
updated to 10.6.7
and also installed all the kexts
AD1988b
AD2000b
AppleHda
Voodoo Ps2
AppleHdaDisabler
the problems are
1) i can't get into snowleopard without adding -x -v on boot and finally be in safe mode.
2) i can't get access to my ATi 5750
3) i can't use my sound card ASUS XONAR D2 (neither from my on board one)
4) i can only use 2 GB of ram. if i place the other 6 i can't get into snow leopard
HELP!!!!
Top
 Profile
PostPosted: 22 Jun 2011, 19:26
Staff
Probably related to your video problem.
If it doesn't work with latest Chameleon, try Kabyl's version
http://www.insanelymac.com/forum/index. ... pic=231768
or injector kext from netkas
http://netkas.org/?p=465
You may need to use "arch=i386".
What's the audio codec? You shouldn't install both legacy kexts, just the right one
lotos wrote:
AD1988b
AD2000b
Remove dsdt.aml, add RAM and run Auto-Patcher again.
Top
 Profile
PostPosted: 22 Jun 2011, 21:21
Noob
i've made a format (once again) without downloading this time the combo update for 10.6.7....
i've managed to work 8 GB of my RAM
i can't understand how to tweak my system for the ati 5750 :( :( :(
my sound card is this one : http://www.asus.com/Multimedia/Audio_Ca ... ifications
p.s
i don't know what arch=i386 is....
thanks
Top
 Profile
PostPosted: 22 Jun 2011, 22:10
Staff
I don't know if this audio card works on Mac OS.
Your on-board audio should work with VoodooHDA
http://code.google.com/p/voodoohda/downloads/list
About video you need to update to 10.6.7, install latest Chameleon (or Kabyl's version) and
Maybe you need "arch=i386" in kernel flags.
Other method is using ATY_Init.kext from netkas site.
You may need to add the device ID to ATI5000Controller.kext/Contents/Info.plist
Code:
<key>IOPCIMatch</key>
<string>0xinsert device ID here1002 0x68981002 0x68991002 0x68E01002 0x68E11002 0x68D81002 0x68C01002
0x68C11002 0x68D91002 0x68B81002 0x68B01002 0x68B11002 0x68A01002 0x68A11002 </string>
Top
 Profile
PostPosted: 23 Jun 2011, 12:00
Noob
i've updated again to 10.6.7 and of course i can't boot.
i've booted from hackboot cd , i've installed again the chameleon i've generated a new patch and for one more time i can not boot in snow leopard withoun the hack boot cd.
any help??? :cry: :cry: :cry:
Top
 Profile
PostPosted: 23 Jun 2011, 15:27
Staff
Why can't you boot? What's the error?
Did you follow the suggested procedures about video card?
Top
 Profile
PostPosted: 23 Jun 2011, 17:10
Noob
yes i have opened lizard and then install chameleon again.
Top
 Profile
Users browsing this forum: No registered users and 0 guests
Search for:
Jump to:
