olarila.com
Mac OS X x86 - Hackintosh
It is currently 22 May 2013, 03:54
Post new topic Reply to topic  [ 160 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 16  Next
Author Message
PostPosted: 15 Jun 2011, 01:45
Staff
ctuprde wrote:
Wow, thanks for that! Ok so I did the steps above, and rebooted in -v mode, but I get a 'still waiting for root device' error, and it doesn't boot.
However, when I boot using the bootcd, it does boot.
Any ideas?
Thanks again!
Boot from cd
run on terminal
Code:
kextstat | grep -v com.apple
paste here
_________________
Top
 Profile
PostPosted: 15 Jun 2011, 01:52
Staff
You need to install the ATA drivers (AppleNForceATA?)
Use System Info to check the kext in use when you boot with the CD
viewtopic.php?f=18&t=63
Top
 Profile
PostPosted: 15 Jun 2011, 01:56
GeekInTraining
Any ideas?
Thanks again!
Boot from cd
run on terminal
Code:
paste here
Index Refs Address    Size       Wired      Name (Version) <Linked Against>
  16    0 0x28465000 0x2000     0x1000     es.osx86.driver.EvOreboot (1.0.3) <4 3>
  17    0 0          0          0          com.meklort.symbols.PostbootMounter (10.0.0)
  19    0 0x2e490000 0x2000     0x1000     org.tgwbd.driver.NullCPUPowerManagement (1.0.0d2) <7 4 3>
  20    0 0x2e675000 0x2000     0x1000     com.superhai.driver.PlatformUUID (1.0.0) <4 3>
  34    0 0x33ef9000 0x7000     0x6000     com.nvidia.driver.AppleNForceATA (1.0.3) <33 14 10 7 5 4 3 1>
  39    0 0x33f98000 0xc000     0xb000     com.nvidia.driver.nForceLAN (0.62.13) <38 14 7 5 4 3 1>
  46    0 0x33ef5000 0x4000     0x3000     org.netkas.fakesmc (2) <13 7 4 3>
Top
 Profile
PostPosted: 15 Jun 2011, 02:39
Staff
Install AppleNForceATA
http://nawcom.com/osx86/files/10.6/SATA ... A.kext.zip
Top
 Profile
PostPosted: 15 Jun 2011, 09:23
GeekInTraining
Do i just need to drag the kext into the extras folder? Or is there an installation method?
Top
 Profile
PostPosted: 15 Jun 2011, 10:32
GeekInTraining
Also, i have no sound - even when i boot from CD.
And my resolution for my GPU (Nvidia GTX470) is not right, but i guess that step comes next!
ctuprde
Top
 Profile
PostPosted: 15 Jun 2011, 16:31
Staff
Drag the kext into /System/Library/Extensions and run Kext Utility
http://cvad-mac.narod2.ru/Kext_Utility/
For audio use VoodooHDA (remove AppleHDA to avoid possible kernel panic)
http://code.google.com/p/voodoohda/downloads/list
For video install Fermi driver (requires 10.6.5 or later) and use GraphicsEnabler=Yes
http://www.nvidia.com/object/quadro-mac ... river.html
Top
 Profile
PostPosted: 15 Jun 2011, 17:52
Noob
I've Foxconn G41 Mxe wth only Ich7 (no AHCI) It works on it ??!
Top
 Profile
PostPosted: 15 Jun 2011, 18:58
Staff
Should work. You may need a patched AppleIntelPIIXATA.
Top
 Profile
PostPosted: 15 Jun 2011, 19:00
Noob
mmmm where can i downoload it ? how to but it in the retail dvd ?
Top
 Profile
Users browsing this forum: No registered users and 0 guests
Search for:
Jump to:
