olarila.com
Mac OS X x86 - Hackintosh
It is currently 19 Jun 2013, 13:47
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
PostPosted: 02 Jul 2011, 16:03
Staff
Berlin31 wrote:
Use 10.6.8
add in boot.plist
Code:
<key>GeneratePStates</key>
<string>Yes</string>
<key>GenerateCStates</key>
_________________
Top
 Profile
PostPosted: 02 Jul 2011, 22:16
Noob
thanks a lot for the quick response
i used the iboot + multibeast method and installed 10.6.8. the mistake i talked about in the last post does
not show up anymore. thx again.
but the booting still takes to much time and shows me
no nvidia graphics adapter found
seems weird to me, since i have an ati 4870 512 mb graphic card installed.
do you have any advice
Top
 Profile
PostPosted: 03 Jul 2011, 04:50
Staff
Maybe you installed any nVidia injector kext or NVClockX (kext to monitor nVidia clock and temperature)?
Top
 Profile
PostPosted: 03 Jul 2011, 14:18
Noob
thanks for your help
i attached two files. one shows which i options i klicked in multibeast and the other one shows where it hangs while booting.
i appreciate your help
thx
Top
 Profile
PostPosted: 03 Jul 2011, 16:30
Staff
If you have an ATI card, remove NVClockX, it's for nVidia only. It may not be the problem, but we never know.
Top
 Profile
PostPosted: 18 Jul 2011, 10:02
Noob
hello everybody
I have a X58-UD7 and a 980X@4,30 GHz
and after installing everything like describe, i have this message on the boot
if i understand from the last posts it is AppleHDA which does this pb!
I need to use AppleHDADisabler
But how to inject it without to restart from scratch?
many thx
Top
 Profile
PostPosted: 18 Jul 2011, 18:28
Staff
gds wrote:
hello everybody
if you use VoodooHda
use AppleHdaDisabler in S/L/E or remove AppleHda
_________________
Top
 Profile
PostPosted: 18 Jul 2011, 18:32
Staff
You can use TransMac if you have Windows in this PC, or single user (boot with -s)
Code:
mount -uw /
rm -r /System/Library/Extensions/AppleHDA.kext
exit
Top
 Profile
PostPosted: 19 Jul 2011, 04:49
Noob
Many thanks
right now i can use SL :)
everything is perfect
BUT my GTX 285 and my ALC889 are not recognized :(
how to modify it?
Top
 Profile
PostPosted: 19 Jul 2011, 04:59
Staff
gds wrote:
Many thanks
how to modify it?
Video
use GraphicsEnabler=Yes or NVenabler.kext in S/L/E
Audio
use VoodooHda
_________________
Top
 Profile
Search for:
Jump to:
