olarila.com
Mac OS X x86 - Hackintosh
It is currently 24 May 2013, 11:54
Post new topic Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: 14 Jun 2012, 16:02
GeekInTraining
Cassio wrote:
Como eu disse, o multiplicador varia de acordo com o uso.
Se abrir o terminal e rodar o comando yes, deve ficar sempre no máximo.
Exatamente, és o cara! haha..
_________________
Gigabyte GA-Z68X-UD4-B3 • Intel Core i5-2400 3.1GHz • 8,0GB DDR3 Gskill 1600mhz • SSD Vertex 4 128gb + HD: 500GB • GeForce GT 9600 • Mac OS X 10.7.4
Top
 Profile
PostPosted: 21 Jun 2012, 15:08
iGenius
Update:
Script atualizado (por Pike) com suporte a Ivy Bridge
https://raw.github.com/Piker-Alpha/Revo ... dtPRGen.sh
Rode os comandos no terminal para baixar e executar o script
Code:
curl -o ssdtPRGen.sh https://raw.github.com/Piker-Alpha/RevoBoot/clang/i386/libsaio/acpi/Tools/ssdtPRGen.sh
chmod +x ssdtPRGen.sh
./ssdtPRGen.sh
Quote:
Script para gerar SSDT
http://revogirl.wordpress.com/2012/06/1 ... dt-pr-dsl/
RevoGirl wrote:
Bash script to generate ssdt-pr.dsl
June 16, 2012 by RevoGirl
I wrote a bash script, on the airport on the day that I left for my vacation to Spain, but I was unable to finish it. Until today that is. What does it do? Simple. This script creates a ssdt-pr.dsl after running the following terminal command:
Code:
sudo ./ssdtPRGen.sh 95 3700
The above example creates: /tmp/ssdt-pr.dsl for a i5-2500K
It works almost fully automatically, but we need to supply two arguments, TDP and max turbo frequency. Easy huh?
You can get my script from my dropbox account here.
p.s. There are variables in OS X that cannot hold any frequency above 4.2 GHz and thus they should NOT be used – going over 4.2 GHz means that you end up with negative frequencies!!!
ssdtPRGen.sh.zip
_________________
Top
 Profile
PostPosted: 27 Apr 2013, 22:05
eGeek
Olá! Estou tendo problemas com o meu processador e as tabelas SSDT.
O sistema sobe até o macx_swapon SUCCESS mas não dá vídeo quando coloco a tabela SSDT criada pelo script do pike.
Estou usando o clover 1378. No chameleon a ssdt é reconhecida perfeitamente com turbo (x31 State) e tenho geekbench de 11 mil. Já no Clover com o IvyBridgeState=Yes só vai até x23 e tenho GeekBench de 9 mil. Gostaria de saber se tem uma solução. Em anexo vai meu script gerado pelo pike e a config.plist do clover.
Obridadooo!
http://cl.ly/Obf1
_________________
ASUS G75VW-RS72 • CPU: Intel Core i7- 3610QM 2.29GHz • RAM: 12 GB ELPIDA • HD: 240GB CORSAIR GS SSD (MAC OS) HD 2 750GB (Win 8) • GPU: GeForce GTX 670M 3GB 1920x1080 • OS: Mac OS X 10.8.3 • BIOS: 222.
Top
 Profile
PostPosted: 27 Apr 2013, 22:25
iGenius
Olá,
tenta desativar estas opções ao usar o SSDT.aml
Code:
      <key>DoubleFirstState</key>
      <string>No</string>
      <key>EnableISS</key>
      <string>No</string>
Se o problema persistir, acredito que seja bug no Clover, já que no Chameleon a tabela funciona. Recomendo postar no tópico oficial do Clover, o desenvolvimento está bem ativo e logo devem corrigir.
_________________
OS X 10.8.3 Mountain Lion | Mac OS X 10.7.5 Lion | Mac OS X 10.6.3 Snow Leopard | UEFI multi boot
Top
 Profile
Search for:
Jump to:
